  • Replies 152
Posted Images
I dont know maybe I should leave this power plant in call it cute power though I could never shut the bonnet on her my beautiful grandaughter
she likes to help popa only trouble she likes to help with a hammer arrrr noooooo :(
awwww!!! That's adorable!!!
https://www.sau.com.au/forums/topic/132547-again/page/5/#findComment-2953334
  • 4 weeks later...
Hi guy's and gals
Haven't posted for a while been busy at work ,6 days a week suck,just thought i'd post up some picks of where its at now .
Going on holidays at the end of the week so hopefully will get it finished then
https://www.sau.com.au/forums/topic/132547-again/page/5/#findComment-3013397
Peter
I have read and studied this topic in detail and I am totally impressed by your attention to detail in your rebuild.
At a technical level there are a number of things that you read about that everyone talks about but in practice no one does (eg oil return line from back of head into the sump). Your attention to detail in this area is better than anyone else that I have seen.
You are to be commended on your rebuild and I would like to see the car in the flesh at a SAU function to further admire your work.
https://www.sau.com.au/forums/topic/132547-again/page/5/#findComment-3015254
Hi All
getting closer just thought id post some picks of some intresting info i came across with the nismo fuel pump and the gtr fuel pump seems there the same numbers on them tried to take a pic but don't think they turned out to well, bought from nengun and same part numbers for rb20 and sr20det the nismo one has a band around the top.And a bit of a pictoral on removing the hicas and plumbing and what I did the reroute the p/s fluid and fitting hicas lock bar as well as fitting pineapples for traction
post-7066-1175677068.jpgpost-7066-1175676884.jpgpost-7066-1175676792.jpgpost-7066-1175676689.jpg
https://www.sau.com.au/forums/topic/132547-again/page/5/#findComment-3029528
Ok guys and gals
Car is 95% complete and running took it for its first run on saturday night felt good to drive it again had to make it short though cause the oil cooler has a slight leak that has to be fixed latest engine bay pick's up for you with some old pic's of what it used to look like
Cheers Peter
https://www.sau.com.au/forums/topic/132547-again/page/5/#findComment-3052670
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
