I can reccomend a place. Sydney Central Panel. They just did a full respray on my 32 GTR. And I mean the whole hog, all windows out etc etc. very nice job. They have done a number of things for me now, and best of all they are very trustworthy. Speak to Tony, or Josh. 9319 6044 , Regent St Redfern. Anyone who's seen my car since the re-spray I'm sure will attest to the quality of the finish.
PS, tell Tony that I (Richard) sent you there. He will look after you.
So if someone goes there and gets some work done he won't get as good a job done cause he doesn't know you or said you sent him? Seems pretty unfair? :laugh:
Louie at exclusive colours also does a great job at a great price :)
I'll second that, Louie does an awesome job at a great price!
Give em a call 9631 2345. There at 431 Great Western Highway, Wentworthville just off the Cumberland Highway.
Cheers
  • 3 years later...
Did a search, and this seemed to be the longest thread in the nsw section, Anyone got any other recommendations for getting a respray done?
Current is currently Bayside blue, but paint is a bit shit, full of scratches and chipping. Also panel gaps are a bit shite. Want to get it resprayed in the same colour and some panel alignment/work done, so would only be a close door job I suppose. Engine bay is in white already, so can't really be stuffed with that. Would be happy to have the car in the shop for a few months i needed. Asking up here, as the number of shops in canberra is limited.
Don't want/need a show quality finish, just need a nice job.
Louie does a top quality job for a great price. Give him a buzz and see when he can fit you in. His been respraying liners for SAU for years.
Xclusive Colours in Smithfield..
Louie Franco
(02) 9756 6797
0413 581 099
or, Andy also does good work..
Complete Smash in Kirrawee..
Andy Divine
(02) 9521 3933
get it done in Thailand, i looked into it last week after noticing they love to rice out there cars, bikes and tuk tuks ect....
around 10 000 baht (around $350 AUD) for a whole car, any car depending on how hard the paint is to mix up, and the jobs i saw were equivalent to our standards here, and when you think of it, why are our spray painters charging us so much anyway? not like they went to uni and studied for 7 years to do it....
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
