OK! heres a Question who the nissan fast can idendify the interior trim colour and type? can you tell me how you did it? is says C
~~ hc33 003262 ~~
I hate the comon poo coloured laurels but there is a black/grey interior i would kill for. FAST says it has a build date of 89 01 so it would be eligable for import just missing the 88 model cut yes? i think its 89 jan and older that makes it. sorry but im learnin haha
m guessing he mean BNR32 not HNR
heres the result
<<<<< P.S. how do i see the 'attached thumbnails' as I can't see anyting here.
Thanks for having a look guys, just went and double checked and go the other number if that helps.
HNR32-007303
with : KRNR32RGFSLMEB
the car is a gts4 not a gtr if that helps
thanks
Stephen
should just be a small thunbnail you can click on.
found the HNR number after i entered the model code then entering the 2nd part of the HNR code...bit strange...anyway here you go
thanks for doing that, only one prob for me at the moment is that I can't see any thumbnails. is there a setting in IE that stops me from seeing thumbnails
again , any help appreciated.
thanks
Stephen
I have a S3 GTR apparently could be a 98...go figure. Having alot of trouble getting parts for the gearbox as it is different to all other GTR's for some reason. The car has factory leather also...weird. I also have a 56K issue. Could someone help me Pls. =)
here are all the details I could find
E-BCNR33
Chassis BCNR33-043389
Model GGJPRWFR33ZZA-EQ-C (changed)
FS5R30A (Trans type?)
RC41 (paint?)
thanks
matt
That's not a valid chassis number as far as FAST is concerned.  Double check it.  Probably explains why Nissan can't identify the correct parts.
I double checked and it definately has BCNR33-043389 on the blue plate and fire wall. Maybe checking a few numbers out might give me an idea... ie 043387,043390, etc.
According to others my gearbox is the same as a R32 GTR ? not sure how that works.
Which part refers to the date of manufacture?
FAST says that GTR #043388 was manufactured in April 1998, while 043390 was an Autech GTR also manufactured in April '98. Only Nissan knows why your car VIN is invalid, but you might be able to get away with buying parts using the 043388 number since at least theoretically yours should use the same production parts.
Yours should have a late series pull clutch type GTR gearbox, but I suppose it's possible an R32 GTR gearbox was fitted as a replacement at some time.
The date of manufacture is determined from the complete VIN.
Ok, cool. Sounds like it could well be a 98...crazy, can't say I've ever heard of a Series 3.5. Makes sense tho with the weird stuff it has on it, like big sump oil cooler, leather and nismo dials.
What is an AUTECH ?
I checked as my clutch and box is out and the clutch is a pull type. I'm going to the gearbox specialist tomorrow to check if some parts i orderd for a 12/97 and newer fit.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
