Hi all,
can someone please check this VIN 6U9000ENR32309186.
Thanks heaps
Hi guys,
Can someone please give me the details of 6U9000 ECR33 031142. Car Im looking to purchase this friday, so quick respnse would be greatly appreciated.
Cheers
Lee
Both PM's replied to.
FAST searches done :pwned:
Hi,
Can someone please check:
vin: bnr32301171
engine#: rb26032431a
What year body / engine?
What paint colour too if you can tell?
Greatly appreciated..
Thanks
Here you go.
* R32 GTR
* Built in March 1993
* RB26DETT
* 5 speed manual transmission
* Exterior colour 326 = Crystal White
Hi i Purchased a R32 today ... i pick it up next saturday ....
Could you please check the Vin i think its ...  HCR32060534
It should be a 1990 4dr black sedan turbo .... its from a dealer ... and im the first australian owner ... it gets its compliance plate on monday
Thanks in advance
Thanks SMR33,
Think someone in the forums said the KH3 Black was a rare colour?, or was it just one of those sales quotes?.
that is "gtir" black....not rare on that car :rolleyes: but could be on a 'line
Hmmm well the guys writting is hard to read ... i hope i read it wrong lol
whats HCR32060531 ??
awsome so that vin number is fine? aslong as colour 732 is black lol ....
Thanks very much ... and i just saw that it said type-M .... i saw some threads abou that i might have to go read the difference properly now.... hopefully its all true and i have a type-M :P
Hi guys my dad just bought a vspec2 r34 gtr and the vin on it is gf-bnr34-006706 and some other numbers and letters are ggjprwyr34zdaavk-d. could someone please find out the specs on it. we're really confused about this car and as to what it is.
thanks
thanks
Well it's not a Vspec II. Its an April 2000 Vspec. Vspec II's weren't made until August 2000. The differences aren't exceedingly large. The main ones being the bonnet and the rear rotor size which is slightly larger on the series 2 R34 GTR. Oh and the sticker on the back!
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
