Can someone check this car for me? If you can tell me where to get the program myself that'll be better than bugging people to decode for me.
http://www.carsales.com.au/pls/carsales/...4&make_id=5
VIN: 6u9000bnr34
Cheers
http://www.carsales.com.au/pls/carsales/&a...4&make_id=5
VIN: 6u9000bnr34
Cheers
you need the last 6 digits of the VIN for that.
i got this programme and used iton a r33 im i nthe process of buying... apparently the 2 door manual is actually a 4dr auto??? the caryard guarantees it is all genuine though? is it possible that the vin was swapped back in japan and once here the compliancers had no idea? or is it more likely something dodgy has happened while in aus.
thanks.
  • 5 weeks later...
thanks.
It could be a simple case of transposing a number when you ran the VIN through FAST. Post it up or try it again for yourself just to double check.
ER34021493
Model: R34
Series: 25GT
Built: February 1999
Colour: Athlete Silver
Body: 4 door sedan
Transmission: 4 speed auto
I ran my vin through Nissan FAST to look for the part number for the a/c compressor and it came up with two different a/c compressors with different part numbers.
Does this mean that they are both compatible with my car?
Can anyone help me out?
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
