thanks mate , apologies i realized after i posted you weren't charlie, my bad lol
the car i was looking up isn't the one in the avatar , its a friends ones , we were hoping to find the original colour , looks like that's evaded us again.
but thanks again or the info everything helps , much appreciated.
  • Like 1
All good :)
What colour is your friends GTR?
As in just by looking it... Post a pic.
Better yet, just post a pic of the Blue Plate and show me here.
hi can you run this bnr32308955
is there anyway to tell if my motor has the upgrades oil pump and crank?
With the Oil Pump, have a look at it and check the part number on it.
15010-05U12 = Stock
15010-24U01 = N1
15010-RR580 = Nismo
The crank... Unless you know it's upgraded, have proof it's been upgraded, there is no other way unless you open up your engine to take a look.
All good :)
that's the thing , no blue plate on it otherwise the colour would be on there like mine, its only got a green plate? this is the car below.
thanks mate
thanks mate
I see... The Green Plate is the Compliance Plate...
Does it look anything like this below: (Example Only)
Should still have the VIN on it...
Or, take a look up against the firewall as it should be engraved on there: (Example Only)
thanks mate
Looks like just a custom paint job or someone tried to replicate Top Secret Japan Gold:
r331.jpg|
But it will never be accurate, as Top Secret do not specify a paint code for it and in the sunlight, it can look different in colour.
What colour is his engine bay?
engine bay is the same colour , we have tried looking inside doors inside rubber strips, boot ect cant find any trace of what it may have been originally.
but your right the paint looks custom , and yes the green tag "the compliance" is the only tag on there ill have another look at the vin on the firewall
but im sure its where i got that BNR number for you , its the only number on there?
I see, looks like the precious owner got a very thorough paint job done and did the whole lot.
In that case, check the Compliance Plate VIN and see if it matches with the VIN on engraved on the Firewall.
Post the VIN that is engraved on the firewall in here and see how we go.
And yes the Firewall will only have the VIN engraved on it.
  • Like 1
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
