  • 1 year later...
  • 1 month later...
  • 1 year later...
Hi All,
I've found a better font for FAST than MS Gothic IMHO.
Actually, now I have played with both, I have settled back to MIGU 2M in 12pt size. Anyway, try them yourself, and see which works well on your own computer display, and what you like to look at.
migu-1m-regular.ttf Migu 2M Regular.ttf
  • Like 1
  • 1 year later...
Sorry, I'm just a parts interpreter and IT specialist who is familiar with the Nissan FAST software. I'm not a Skyline expert.
I'd suggest to answer your question, you might need to decode the model information:
GGJPRQFR3ZDAAA--A
I don't have that information, but I may be able to find something burried in the data. And if you know a specific part unique to a model, I can use that. Like knowing that a particular vehicle has a unique badge, like my Terrano has a badge 'G3mR' which means it has a factory turbo QD32Eti engine. Or that my Terrano actually has a Patrol rear diff, but double row rear axle bearings which are very unique and special to my model only.
On 17/09/2022 at 6:40 PM, ant_civic said:
Can you find out if its a n1 or what it is please
 @sin-told you what to do on GTR registry.
White January 96 GTR with super fine coat paint.
Not v spec, not N1
This is very good as it has the 31 spline mechanical rear diff which everyone wants.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
