Just took me 1 or 2 goes to enter the info in the correct fields and all good from there.
Am hoping that funkymonkey or others are able to work out how to query the databases on stuff. eg I want to know the number of vehicles made with my paint code.
ps Your colour 326 shows as white btw.
thanks guys.  Very strange as that is how I entered it and it did not work.  Just tried again and it has now got the information.  I wonder is it has to index a database or something before working?
maybe you tried bnr32 .. not brn32 as you first post read
Well Sameer ( Horus ) is selling a great low klms GTS-t 89 that is eligble for import in September for $10,000 Landed and Complied.
Here is the chasis number , can people get some more info on the car if possible with the '""fast""" software from nissan ?
thanks !
HCR32-026287
  • 1 month later...
Guest Variable
Hi guys,
I've got FAST working thanks to Strutto's great instructions, found my car (whew!) and noticed many of the part numbers in the exploded drawings are only 5 digits. Any parts I've bought from Nissan are usually in a 5-5 format. Does anybody know how to get the complete part numbers?
Cheers
Dirk
  • 4 weeks later...
  • 4 weeks later...
Sorry to ressurect this but it IS possible to get full part numbers using the FAST software. Once you know the part code (the first 5 digits of the full PN), it's reasonably simple, although I suspect there may be a little more to it than what I've found so far. If you don't know the part code, you need to navigate to the relevant parts illustration to find it - I'm not going into it here as others have decribed it earlier (and it's worth trying for yourself anyway to get familiar with the system).
Anyway using the timing belt example (below), go to the initial FAST window and make sure the model series at least or VIN are entered. In this case use R32 or (as I did) your VIN. Now go to the 'Part Code....Qty....Part No' Line and click on 'New', then go to the 'Part No' field and enter the first 5 digits of the PN (ie 13028). The system should automatically enter a dash after the 8.
Now click on 'New' again and a window should pop up with some info about the part (but not the PN....yet). Click once in the blank 'Ord.Qty' box to 'order' one belt (or click as many times as you want for the number of belts you need) - that number should appear in the box. Highlight and backspace to delete quantity. Either hit F5 or go to the 'Tool' menu and select 'P/No Search'.......voila, the PN appears along with a bunch of other stuff in the original 'FAST' window. There's also 2 new buttons in that info list - one gives basic model info, the other gives superceded parts info, if applicable.
Well, it worked for me....
strutto looking at the part numbers on some parts i allready have it does not show full parts listing IE
rb20det
say a timing belt on fast is is listed as 13028
but the full part # is 1302820p25
does anybody know how or where the full parts listing is for each part ?
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
