Hey forum just wanting to know whats the next best gear oil to get as my car has started to crunch just a bit from 1st to 2nd and 2nd to 3rd. It started happening after I changed my gear oil and I was told the other oil I put in may have been to thick. I put in castrol 80w 90 it was suggested that I put in a thinner oil preferrably the redline lightweigh shockproof oil but I'm in the Bahamas and I cant find it anywhere I wanted to know how thin on the weight oil I should go and if putting in a gear oil additive would help I see that lucas has one that I could add to the next set of gear oil I put in wanted to kno if that was a good or bad idea as well?
https://www.sau.com.au/forums/topic/134093-best-gear-oil/
Redline Lightweight Shockproof (smurfs blood) is great.
Only really recommended for worn boxes though. Heard that someone with a rebuilt box had issues.
I've got it in my car and it's brilliant.
www.nismo.com.au (unique autosports) is where I got mine done too.
https://www.sau.com.au/forums/topic/134093-best-gear-oil/#findComment-2494837
Ok so Dont get he heavy shockproof for my problems get the lightweight? Also I see that redline has a superlight gear oil would this be better or just stick with the lightweight? What appilcation if not for my problem would the heavy shockproof gear oil be recommened for?
https://www.sau.com.au/forums/topic/134093-best-gear-oil/#findComment-2502059
I just put Motul Gear300 in my box. But I had no crunching issues so there was no way I was going to touch shockproof after some of the warnings I've heard on here about using them in mint boxes.
I'm still hoping the Gear300 improves the feel a bit, but the old oil was still in good nick so the difference will probably be minimal.
https://www.sau.com.au/forums/topic/134093-best-gear-oil/#findComment-2503128
MT-90 should be used in the gearbox and lightweight shockproof or 75w90 in the diff.
https://www.sau.com.au/forums/topic/134093-best-gear-oil/#findComment-2503190
Let us know how the Gear 300 goes Kinks.
aquariuz6, Shockproof is not for auto transmissions.
Daboss, heavy weight shockproof is for racing applications where the diff/trans sees very high temps. My bet is using on the street will result in worse shifting. Try the lightweight, as the super lightweight may be a tad thin.
https://www.sau.com.au/forums/topic/134093-best-gear-oil/#findComment-2503294
Those are both redline products, and you've basically described what I'm using anyway (in terms of oil specs, ignoring brand).
Busty, I don't expect much to change really, my car has done < 40k kms and the old gearbox oil was still in good condition when I drained it this arvo. Preventative maintenance, really - at least now I know it has good oil in it and I won't have to worry about it for another 3-4 years!
Couldn't get the bastard diff plugs undone though, I'll need to get the car on a hoist so I can have a proper swing at it. The gearbox plugs came undone with just a ratchet :D
https://www.sau.com.au/forums/topic/134093-best-gear-oil/#findComment-2503558
On an auto box can you still use the redline lightweight shockproof or is it only for manual gearboxes? If no, Is there something as good as this oil for auto?
Id go for Castrol Transmax Z. Ive just changed my auto transmission oil to this and the car feels great. It aint cheap: 65 bucks for 4 litres of it and you need 3 bottles for a complete change...
https://www.sau.com.au/forums/topic/134093-best-gear-oil/#findComment-2505145
Noticeable improvement in cold and warm shifting, now it feels like sex. Good sex :nuke:
Big fan of Motul oil, which is ironic because they're French and we all know what french cars are like :)
https://www.sau.com.au/forums/topic/134093-best-gear-oil/#findComment-2517063
  • 5 months later...
MT-90 from Redline is for cars which don't have high k's. So i'd put the Mt-90 in my R34, not the lightweight shockproof.
Maybe that's why people with "new" gearboxes, etc... have had issues with the lightweight shockproof, because the synchro's are mint. MT-90 for the "lower" km gearboxes
https://www.sau.com.au/forums/topic/134093-best-gear-oil/#findComment-2943908
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
