Big Up For A & B Motorsport In Brookvale !
As you may know - I have my fair share if 'interesting' experiences with mechanics & workshops. So when I go to one that give me outstanding service and quality of product (and price) - I like to share the goodness !
So the story goes:
Went looking for some coilovers for my TX3 race car project. A member of TeamEunos (like SAU but for Mazda/Eunos/Cosmo etc) recomended that I try A&B Motorsport in Brookvale.
Talked to Frank, the owner, and he showed my his inverted race coilovers with adjustable everything (damper, height, camber, etc) - they were a good price, so I told him that I'd think about it !
Whilst there - I noticed some 8 piston calipers with massive rotors and I asked him about them for the Cosmo - Although they didn't have a specific kit for the Cosmo - he said he could make one up for me. He also told me that I I took the coil overs, that he would fit the brakes for a good price.
So I went with the deal. He spent 2 days getting the brakes 200% right ! Didn't charge me for the 2 days and he had to make new brackets, and spend a bunch of time with different types of rotors to get the right offset etc.
As an example - the original wheel studs with the new rotors meant that the wheel nuts would only go on 80% - Most other workshop would have just left it at that - But being particular about his work, he hunted down 10 new studs that were 10mm longer that the originals - so that the wheel nuts went on fully and then some !
Very happy with the final result ! 8 Piston calipers, braided lines, all fluid changed, 330mm slotted rotors - It stops like a demon now !
I liked the coilovers for the TX3 - and asked about the Cosmo - again, no specific kit - but he would make one up - Sure enough - Got the car back - and perfect ! Sits lower - he got all the adjustments/allignment and stuff spot on 300% perfect. Ride is firm but comfortable and the car looks a hell of a lot better sitting lower and with the big brakes on the front !
So a big UP to Frank and Rob at A&B Motorsport in Brookvale !
Give them a hoy - if you are after brakes, suspension, etc - They also have a dyno - they don't tune yet - just power runs.
Cheers,
Suprisingly not !
My old rotors were warped - and the Cosmo come with tiny rotors and single pot calipers. So I investigated options - The best and most affordable option was 2nd hand FD RX7 Calipers with RX8 rotors. I figured about $2000-$2500 for this - Also there was a bit of machining and mucking around for this conversion.
Both Calipers, 330mm rotors, braided lines, fluid and pads, including fitting cost me $2,500.
Before the upgrade - front to left difference in pressure was 9% - Now it is less then 1%.
The brake kit is designed in Japan and manufatured in Taiwan - Brand is K-Sport ! (Similar to the ones Just Jap sells) but these guys are a workshop so any non standard stuff or hard to replace items (eg for a Cosmo) - they work out how to do it !
Very Happy !
Suprisingly not !
Very Happy !
Sounds good B-Man.
K Sport are exactly the same as G4 Racing (only the G4 kit is a little cheaper)
All the reports I have heard about G4 have been outstanding in terms of braking performance, particularly on the track! :)
Sounds good B-Man.
really?
nice... i need new brakes and was wondering what G4 were like..
Yeah - they are the same as G4 - However, in my case - if I had bought the kit from JJ, then got an adaptor made, new studs and all the labour - I reckon I ended up paying heaps heaps less !
They are awsome brakes ! absolutely briliant compated to the standard cosmo - there is no comparison !
yep they are pretty cool. i bought som lk-sport coil overs and mucked around with springrates and they were fine with it. also both my rear dampers exploded(pulled the seel in and leaked everywhere) they replaced them no questions asked :P still in warenty but yeah .
i had to turn down the funny spaarkplugs and wierd vortex intake lol
good man. especially if he had press studs on the back of those jeans. i'd he-bitch man slap him. apart from that the brakes look massive, and i like the wheels. good choice bman.
Very nice! 8 piston just adds to the bling as well.
Have you investigated what pads the calipers support? I am guessing porsche?
Bman, to say you have had your fair share of dodgy dealings is a gross understatement :blush: Luckily for SAU club members you have taken enough bad luck to cover the 'team'....... I mean club :(
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
