I got 201.3 rwkw with 651 Nm torque after having my SAFC-II tuned yesterday im happy with it the car feels great
what i want to know is this a good figure for the following mods.
HKS Pod Filter
HKS 3.5" Cat Back Exhaust + 4.5" HKS Muffler
HKS EVC 5 boost controller @ 10psi
Apexi SAFC-II + Tune
Greddy Type R Blow Off Valve
600x300x76 Autobahn88 Intercooler 2.5" piping
Sard Fuel Pressure Regulator
Walbro 500hp Fuel Pump
NGK iridum sparkplugs @ .8mm gap
BP 98 pump gas
Factory: turbo, ECU
Dyno sheet below
https://www.sau.com.au/forums/topic/134528-got-a-dyno-tune-yesterday-2013-rwkw/
Yeh solid result, plenty more power to be made with a aftermarket computer as your A/F reading is floating around a bit. and a bit of fine tuning of your EBC.
Edited by BezerkR32
yea the air fuel ratio is sitting between 11.8 and 12 max at the higher rev range.
Looks like a good result.. How's it feel - what was it before they started tuning??
it was 185 rwkw going way rich after 4000rpm
the car feels much more solid mid and top end. is also much smother and fuel economy is better also.
im pretty happy i was hoping for 215ish but hey im on my way.
:D
Put the cars on the same dyno, on the same day, then compair. That figure is too high in my opinion, especially without a aftermarket ecu, only a cat back exhaust and 10psi :happy:.
mad082, your figure is really unbelievable. Maybe go to the next dyno day in your state, this will give you a fair comparison with other cars and will tell you if your mechanic is "tweaking" the figures :sick:
a dyno is simply a measuring tool for improvement and tuning. comparing one dyno read out in one state to another in another state could be like comparing, well, apples and oranges?!
do more mods to the car and see the improvement that each makes and then u will be heading in the right direction.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
