well i got the short straw as ended up being the designated driver on saturday night...
ive just got into my car to give it a clean and there is chewing gum all over the back seat...
ive tried a search but had no luck,
what products are good to get chewy off seats??
https://www.sau.com.au/forums/topic/134793-removing-chewing-gum/
Guys, this is a really top tip i learnt. Go to Smith's dick, and buy a can of freezing spray.
hit that mofo with the spray like there's no tomorrow, then you can sort of pull it off. Like have you ever got it on your clothes and put the clothes in the freezer? Same thing. I just hope it's very superficial, and not like mashed into the seat.
gonna get some of big kevs (rest his soul) product, if not eucylaptis oil or some of that orange power stuff..
have seat covers on the front for this exact reason, drove once b4 and my mate spewed all over the front seat... Fun times!!!
leading from this, can we get generic seat covers ofr skylines?
Thats the best way to do it i found, no need for chemicals and liquids and shit come of nice and clean. any electronics store should have freeze spray.
seat covers are also a good idea.
Well if theres one thing Ive lernt from this post its the importance of seat covers....just reading the posistion the poor guys in scares the sh!t that one day I might face this issue - so to all those who have been as dumb as me SEAT COVERS evil stories like this really do happen!
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
