I dont care how long this takes, I am starting on my R33 GTST back to original showroom and beyond project so I cant wait for this Badge. If there is anything needed at all just give a shot ands ill see what I can do. I know a lot of graphics and signmaking (stickers etc) dudes...
  • Replies 224
Posted Images
in case anyone is interested, i'm selling my GTS badge from the original group buy, including a "turbo" badge as well for a total of $40. PM me for details.
can be bought if needed to send to the supplier to get it copied for the group buy to get going
cheers,
Warren
image:
http://www.skylinesaustralia.com/forums/in...st&id=71148
thread with details:
http://www.skylinesaustralia.com/forums/in...howtopic=146273
dunno if anyone else has noticed, but this group buy started in september, its now january.. hate to get edgy, and i was like one of the first to post in september... BUT > THATS 4 MONTHS NOW.. going on 5 months in a couple of days... longest group buy i have ever seen..
is it still on or not?, i do not mind, but, would like to know if i can stop checking this post every 4 days..???
Hey guys and dolls,
As beginner of this thread , I to am suprised at the lenght of time to get these things made.
BUT, we have had some set backs and design issues and obviously Chris G is having troubles with the lot hes going thru.
Somehow somewhere we will get thses made.
Even if my wife knits you all one!!!!!
Ha ha so if your interested then please stick around and oh yeah, ......be patient!!!!! :P
R33
krzysiu,
Thanks for the great Pic!
Is not quite like the one i saw from Advan, it was more like the Pic 2 from "savagebliss"
But not to shabby!!!!
Very much appreciated!!
Ok we have seen the goods, whos still in?
the count stands at
Ronin33 x2
LoNg_ShaNks x1
Munna1 x1
jim80 x1
ignuz x1 (maybe)
JaiJai x1
Al x2 (maybe)
Any one else??
Iwould like 1 (maybe a second)
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
