  • Replies 120
Glade to hear everyone got out of the accident intact.
We should all take note of this experience and take care on the roads, especially with winter on our door step.
I want to keep seeing all ya faces on our cruise nights, etc.
yup.. she'z ok i guess.. i spoke to her for a bit last nite, but as you can imagine she's not going to be rushing to post on here for a while.
Everybody: If u know Milk/Vickii and want to see how she is give her a call, i'm sure she would like that, and to talk to somebody who has a kind word.. Like anybody in that situation, she doesn't want to be *hassled* i am sure, so be nice.
Oh dear!!!
not good this is.
Glad to see all are alive, and well to say the least!
My Calais Turbo looked similar to that, but upside down... so i know how it feels and what goes through your head.
But you get over it and back out there soon enough :P
Just take it and learn... be very careful about putting the foot down in the wet, i learnt that the hard way :)
Especially as Al said... winter is close
Good to hear that all is relatively ok now.
Will try call vickii tonight [since her fone is not on yet].
Thinking of you Milky - dont be hard on yourself either!
I have lost it in the wet before in my old bluebird = not fun.
Thinking of you guys :)
Hey everyone!!
thnx for the regards...i am so surprised so many of u cared:)
/me is crying
i am so happy to talk to u guys again..if u guys still wanna me here...afterall i lost the whole car:(
but i am really glad to have so many posts regarding to me sniffy and franjo....i am so sorry 2 sniffy and franjo;...hope they get well soon...
this is my 2nd accident....i am sincerely wishes every friend and club member to take my experience as a warning...dont get into troubles..and play it safe...
ok...laters guys:)muahz!
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
