my gf calls me up and goes one of her friends just died in a car crash and it was on the news.....so i go and turn on the tv faarrr out......2 dead 2 critical and another 2 injured not so bad.
the car was a mess it looked worse then the farrari couple weeks back. i think it was a 300zx.
the news report labled the car as a nissan coupe........nice to know they aint pointing it out as a import...or such other things/.....ill try get more info and some pics.....
heres the story.............
Police believe the car in the fatal smash in North Caulfield was travelling at 140 kmh, twice the speed limit for the section of road.
Assistant Commissioner (Traffic) Noel Ashby told theage.com.au speed was the main factor in the accident which has left two young women dead and four others in hospital.
The women, both of Noble Park, died after the 1989 Nissan 300 ZX sedan carrying six women slammed into a brick fence shortly after 3.30am at the corner of Dandenong and Wattletree roads, police said.
Four other women in the car, all in their early 20s, suffered injuries ranging from minor to critical.
turns out the car was going 140 in a 70 zone.....man some guys realli need to slow down :P
full story here.
http://www.theage.com.au/news/national/car...8431867376.html
Edited by anDru
https://www.sau.com.au/forums/topic/135499-melbourne-car-crash/
  • Replies 52
i know this might make me sound like a cold hearted guy but sometimes i rkn ppl who do those sorta things are lookn to die....so its their bad luck.
wtf are u doing going 140 downa 70...and crashing into someones house....yeh that right...someones house!!!
Dude your right. I admit ive done some stupid shit, heck Ive done 140 Km/h too but... ON A FREEWAY WITH NO CARS late at night! Id never do that kind of dumb shit in a 70 KM zone... more so with 6 people in the car! If I ever do stupid shit then Im alone in the car! I never dare to do that with passengers!
i wouldnt be saying that to your girlfriend anytime soon :)
Oh cr#p... I remember seeing a Darkish grey 300ZX with I think Silver oldish style Enkei's going Caulfield way when I passed the Warrigal/Princess fwy intersection. This was about 3:30am after coming back from the city...
f**k that's scary. In this position, do you think would it be an idea to contact the Police?
when did 300zx's come with 4 doors? :)
They don't they came in 2+2 and the rear seats are REALLY squashy.
Sorry Dezz, strongly disagree buddy :D
Do you think they would be as tempted to do such speeds in a shit-box, i don't. There are alot of sensible P-platers out there (and in this club), but even these people get tempted or pushed into doing stupid thing, because the car has the ability.
I wasn't saying what I said because i'm a p-plater in an overpowered car....
I'm saying she had 6 people in a car that we all know is not capable of carrying 6...you'd be lucky to get 5 in a 300zx comfortably..
and there's no mention of it being twin turbo, so for all we know it was an underpowered and overweight N/A
you'd be hard pressed to get 3 people in 300zx comfortably, have you ever seen the space for the back seats? :)
Jeez - RIP
What were they thinking when they were doing that. It could have been worse, like the one on police rd in springvale. A pedestrian or another road user may have died. Such a waste of life.....
and finally the journalists dont know jack shit about imports, hence they said its a sedan
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
