  • Replies 113
Posted Images
I Just got my NEO dyno'd,
I got 179rwkw with a catback and apexi filter.
The heatsoak was pretty bad, the next run after that I only got 164.
From the mods you have it's possible.
Cheers
Josh
Yea exactly and mine was staying on 13 the whole time. The other guy was saying that if it was the fuel pump the AFR would keep rising... I don't see how tho
i think you are right there. i'd say its probably the fuel pressure regulator.
mayb i should just replace the FPR 1st and see if it fixes it
Should i be getting any particular brand or just get a stock1?
nismo ones are cheap and well tested .. and just fit inplace of the stock one easily
Depends on your long term goals.
If you don't plan to throw a highflow on it just grab another cheap (if they are cheap that is) stock item from a wreckers and try.
Otherwise.. grab a nismo item. They work well and are well priced. Grab one from nengun/perfectrun and the like.
You can't just throw a FPR onto a stock ECU. It'll mess up the fueling on anything but full throttle.
Also AFRs at 13 wouldn't be responsible for the high power. The power difference say between 12 and 13 might only be 2-5% max. 196rwkw at 8.5psi.. sounds like an RB30 haha.
what i find odd is that the AFRs are almost dead flat all the way through, even though it is lean
maybe its not actually a stock ECU? have you checked what it looks like for some kind of sticker? or opened it even?
Nah havent checked it, i jus assumed it was stock i guess. I'll do that this weekend and let u guys know. ECU is located under passenger side kick panel right?
yeah but if anything that would make the figures more realistic..
its when IT is way higher than AT that you see higher figures, so with the values around the same the computer won't apply much (any?) correction...
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
    • @GTSBoy yeah sorry i know thery are known for colors bud those DBA are too in colors 🙂 Green will be good enough for me
    • That's my life. Past-Duncan has a lot to answer for
    • Yep four point harness. Mounted to a bolted in brace running behind the seats. Dont use it for daily driving tbh but good to have for when its needed plus it looks cool.
    • I had to double check the thread title r34 gtt offset advice lol. Thought maybe i posted on the wrong thread. 😂
