Hi all
I have a question.
Say if you up the boost of your car by using a boost controller and boost reads 10psi,
is it the same as your boost getting upped by a full exhaust to 10psi?
ie. is the effect of a full exhaust increasing boost the same as actually boosting it up via some controller?
I ask this because I have read on these forums that a boost increase by an exhaust isnt actually different to a controlled boost increase. Some have mentioned that an exhaust boost increase is not an actual increase in turbo pressure, something about the boost in the engine being different to boost in the actual turbo itself?
*confused* maybe Ive read the posts wrong.
Thanks
Hmm I already have one and boost has gone from 8 to 10psi because of it.
Just wondering whether getting an EBC will give me more power if I set boost to 10psi, ie. will I be able to run "more" boost in the actual car if I dial it in at 10psi.
Or will I have any other significant gain.
I think you forgetting the fact that you guage should be reading maifold pressure.
10psi is just that.
It is a figure there is no diff between 10psi achieved through any boost controller or by an exhaust.
Don't forget that a boost controller does just that; controls the boost... if you set it at 10psi then it will constantly stay at 10psi.
However, if you think about it, controlling the boost with the exhaust mod will not be as accurate, there will be fluctuations.
mine reaches around 9psi, stock boost solenoid, exhaust and pod.
r33
have u got turbo back? or cat back. that may be the difference. also, highflow cats etc.
Edited by Munkyb0y
if you are only going to run 10psi i wouldn't bother with a EBC. that is a lot of money to spend to gain a very small amount. i'd get one of the $22 boost controllers. that will bring the boost on earlier.
Make sure you understand boost first.
Your engine burns fuel and air and send it out the exhaust manifold which flows past the turbine which it spins along the way.
Which in turn spins the compressor wheel which sucks in the air. And the whole process flows through.
Now, you get a larger exhaust, the gases coming from your engine has more room and can flow more, and there is less back pressure at the exhaust wheel of your turbo, which means it spins more, which in turn spins the compressor wheel, which sucks in more air to the engine.
That is the increase in boost pressure.
No factory set up measures the boost pressure at the turbo.
It is always measured AFTER the throttle body.
So with the intercooler in the way, your turbo might actually be spinning up 12psi of pressure but the intercooler is a restriction and by the time it gets to the engine, it is only 10psi worth.
All the factory restrictions like the back pressure caused by stock dump pipe etc, and the restriction in the intercooler, or the stock air filter maybe..
Once these are freed up, you will see a higher pressure amount.
Is there a difference between 10psi via a boost controller or via the free flowing exhaust?
NO.
Is there a power difference? you bet there is.
Do a search for “ BOOST+SYDNEYKID” from any date.
He had a really good explanation of boost and so on.
Unless he sees this and posts it here himself.
hang on GTST, higher flow due to lower restriction should lead to a decrease in pressure. (depending on where you are measuring it). then you load up some pics of Bernoulli's Effect and your head gets more messed with.
Edited by wolverine
theoretically the boost pressure shouldn't rise with an exhaust size increase. why? if you start flowing more air out of the exhaust, the turbo will spin faster, and compress more air into the intake. the wastegate should see this and open sooner, but still at the same pressure, slowing the turbo back down. the only way that the pressure could increase is if the wastegate can't flow enough air due to a higher restriction.
you're all forgetting something guys... what about "wastegate creep"?
yes a boost controller and exhaust will both work to increase MAX boost level,
BUT
with a full exhaust, the wastegate still creeps open at low-mid rpm giving you a gradual increase in boost
a boost controller stops any manifold pressure getting to the wastegate actuator until max pressure, so it will build boost faster than simply having a free-flowing exhaust
of course having a boost controller with no aftermarket exhaust is also kind of stupid as throwing all that exhaust gas into a restrictive pipe isn't going to yeild as much power so why bother upping the boost at all?
Warren.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
