HICAS vs No HICAS (Track use)
34 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hey guys,
Ive just bought an 1992 R32 GTSt and am planning to take it to track for a bit of fun. It has HICAS installed at the moment which as far as I can tell works fine. (HICAS light comes on sometimes due to a bad contact somewhere - which goes away when you spray contacts with contact cleaner).
Anyways real question is what do you guys think? Would I be better off removing the HICAS? I personally think its crap but have had a few friends (who have had 4WS cars but dont know anything about skylines) tell me that maybe it just takes some getting use to....
I think its fine for the road but dont like it when turning under speed - so whats the verdict?
Comments welcome
Edit: One friend even suggested trying it with HICAS atleast once which is also an option i suppose...
Edited by ZENNON
You can keep it for a little while. I have been out with HICAS still on, didn't kill me..
The general consensus is remove it when you can for more predictable handling, but it's not mandatory if you are just out there to have some fun.
it's pretty easy. unless u did wat i did and didnt crack the 2 nuts before removing the 2 main bolts that hold it inplace :wave:
ah yeah ive heard people complain about that... you wouldn't be able to show me in a pic which nuts to crack before i undo which bolts...
would be very helpful
I rekon leave it on, go to track day see how it goes, then if it feels funny take it off for the next track day. This way you will be able to feel exectly what the change does.
Sam
Yeah what Gordo said. HICAS makes it a bit difficult to hold a precise line mid-corner (because the computer decides it wants to change the angle of the back wheels :wave: ) and can make it feel a bit nervous. That said, to the day I sold it my Skyline still had the HICAS connected and working, once I got used to it I just let the rear end wander a little, and made small steering adjustments to keep my line accurate. It does feel a bit wierd but you can drive around it.
Also consider though, the effect a lock bar may have on your insurance/wallet. This is second hand info so I'd be checking it yourself if you're concerned, but I'm told lock bars are illegal because they are a modification to the steering systems. You could be defected for it, and if you crash you may not be covered. I never followed this up myself because I had no need to, but it might be worth checking :D
thanks for the advice guys
Yeah what Gordo said. HICAS makes it a bit difficult to hold a precise line mid-corner (because the computer decides it wants to change the angle of the back wheels :no: ) and can make it feel a bit nervous.
Yeah... I think Ill see how I go but Im inclined to remove it...
Also consider though, the effect a lock bar may have on your insurance/wallet. This is second hand info so I'd be checking it yourself if you're concerned, but I'm told lock bars are illegal because they are a modification to the steering systems. You could be defected for it, and if you crash you may not be covered. I never followed this up myself because I had no need to, but it might be worth checking :kiss:
Nah itll be fine! :laugh:
where do people get the lock bars from? I got an r33 and was going to take mine off but didnt really know where to get the lock bars made up. I've taken corners at high speeds before and i think the skyrice handles fine even with the hicas
I really had no problems with the handling under hicas, I just didnt like a computer cutting in on my driving, I used the Tomei kit, which gives you the option of going back quite easily for the 33, with the 32s the Hicas is hydraulic and a weight saving can be had by its removal.
If you want full control then remove hicas...
If you want some help then leave it in...
I used to race go karts and hicas just messed with my driving style so i removed it quick smart... Im just used to not having it so it was an easy decision for me... Also it does scuff your tyres on the inside edge on the rear faster then with out hicas...
hicas is 4 wheel steer...
Well not really 4 wheel steer just more like the rear wheels moving slightlly a couple of degres to help through corners...
There are 2 types of hicas, there is the one where the whole rear suspension moves like found in the HR31's and then there are ones with an actually second steering rack just for the rear wheels like in the 32,33,34...
Personally i dont like hicas...
My bf purchased a tomei lock out kit for his 33 off nengun.. as his car was actually CRAB WALKING as a result of of the hicas LOCKING ON in one direction..
It's all been installed now.. and car drives straight! :P
In 32's it is much easier to fix as the hicas is mehanical where as the 33's have an electrical one.
I drove my 32 with the hicas light on and it was gay to drift.. as the back wheels had a mind of their own!
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
