Hey guys,
I wouldn't mind knowing where all you guys are at in terms of mods and power and where you are headed?
What figures would you be happy with?
Ill get the ball rolling...
I've got:
Exhaust
FMIC
Power fc
Boost contorller
Fuel pump
Air intake pip
Pod...If there is more ill add it later.
After my tune on saturday I should have around 220kw atw i was told by autotach so im happy about that. For the future I want to get injectors and a turbo and maybe do some internal work. The magic figure i am after is 300kw atw so i am aiming for that in the next year or so.
What are your ''happy place'' figures :P
I got my tune this morning and im pretty happy with the out come.
Edited by R3sp3ct
https://www.sau.com.au/forums/topic/137388-future-dreams/
As far as current mods go, it's just a cat-back and a pod for me.
Future plans are only shooting for around 200rwKw. So my plans for future power mods is looking pretty much like your current list R3sp3ct.
As for other stuff, plans for coilovers, sway bars and strut braces. Then, Final Konexion kit, flat oem style carbon bonnet and hopefully a flush carbon bootlid will make my car look hot as... In my opinion anyway :P
https://www.sau.com.au/forums/topic/137388-future-dreams/#findComment-2556514
My future plans for my car are getting it back :P
After having owned it stock, with twin lowmounts (2530's) making 300+kw, I decided to go all out and punch for the 500-550kw mark on pump fuel.
To let some secrets out, parts included are a JUN stroker motor and the big momma T88H-38GK.
EDIT: Oh and theres also a respray in there too in a secret colour :D
Edited by Amaru
https://www.sau.com.au/forums/topic/137388-future-dreams/#findComment-2556573
I've got a few little mods in mind, but not many are aimed towards performance as the insurer is quite strict about what can and can't be done.
I'm looking to install Hybrid FMIC, and run a bit more boost.
A set of 18" Lenso Muse rims are pending approval from insurance company, hoping to have them on very soon if approved.
Recently upgraded the stereo in my car with new kevlar front splits, just bought two 12" Type R Aplines and have a Class D 800W amp on it's way, will install these in the next couple of weeks in custom enclosure. replacing the existing 12" sub and underpower amp.
Planning to tint the windows and touch up the scratches on the car. should do me for a while. Very excited about it all!
https://www.sau.com.au/forums/topic/137388-future-dreams/#findComment-2556582
I'm lacking a good turbo [working on the turbo angle atm] and some suspension mods, looking at 260-280, I'll never get to 300 with this car!
My main mod is to replace my car with a SIII R33, but that'll never happen either - real estate takes all........
https://www.sau.com.au/forums/topic/137388-future-dreams/#findComment-2556664
I bought a stock R32 GTST stock stock stock!!!
so far my mods are
3"turboback with split dump
trust FMIC
ECU remap
boost controller
currently about 140rwkw of fury...
Mods bought and going in really soon
metalcat 3" cat
GTR injectors
GTR fuel pump
Z32 AFM
RB25 hiflow or 2530 if I can find one
Power goal is 220rwkw that is not too laggy. it should be plenty to motivate the little R32 and should have it all done by xmas.
Other mods will be
mechanical LSD
RB25 gearbox
brass button single plate clutch.. I love bitey single plate clutches :0
this will prob happen when the current gearbox dies.
going to keep the car looking as stock as possible and not loud either the police cops don't like loud skylines hehe..
https://www.sau.com.au/forums/topic/137388-future-dreams/#findComment-2556858
Well if you all are posting your running gear and anything else ill tell you mine...
Cusco LSD
Coilovers..HKS rears/GABS fronts
Front and rear strut braces
Full adjustable suspension surrounding the coilovers (not sure what it all is)
5 puck clutch
Custom dump pip to full 3.5" exhaust system
Upgraded front breaks
Think thats it...
Edited by R3sp3ct
https://www.sau.com.au/forums/topic/137388-future-dreams/#findComment-2556959
Custom gear box
what does a custom gear box contain?
my near future goals are:
5spd GTR gearbox
PowerFC
Hi-Flow turbo
then i'm pretty much done with the madwagon. it's not a race car.
my far future car goals are to have a car that runs when we run out of oil in 30 years
https://www.sau.com.au/forums/topic/137388-future-dreams/#findComment-2556961
My cars future = consistant reliability. Hasn't been that way since I bought her and it's cost me bucks to revive her.
I'm happy with the 300+kw mark, so suspension and brakes, then a respray.
Should check out the Rides sticky. Has a lot of ppls existing set-up.
https://www.sau.com.au/forums/topic/137388-future-dreams/#findComment-2558300
So far i have
3" split dump/front, 5" cat high flow, 3.5" kakimoto exhaust
hybrid FMIC
Apexi pod
Lookin at 044 pump, powerFC with boost controler, injectors, hoping for around 210 at the rears then move onto bigger turbo and hopefully hitting around 275 (with other mods)
https://www.sau.com.au/forums/topic/137388-future-dreams/#findComment-2559626
nice power and a nice safe afr ratio too you could lean that out a little more too if you wanted eg 12:1 and maybe get a smiggen more power but probably not worth it,
Yeah thanks mate, Pete was very happy with how it all went this morning he said it was all in good running order so thats really good. He also said next will need to be, coil pack, injectors and turbo so i will work on that now. :D
https://www.sau.com.au/forums/topic/137388-future-dreams/#findComment-2563282
garret 3082
greddy intake plenum
Hybrid gt spec fmic
Hks cams and gears
chrome molly flywheel
rb26 crankshaft
tomei pistons, rings and rods
ap engineering pfc and hc
turbosmart eboost II compact ebc
cold air induction and box
nismo/cusco lsd
twin plate clutch
adjustabe coilovers,camber arms etc etc
splifire di injection kit
stainless low mount exhaust manifold
3.5" stainless exhuast
big brake kit
full respray and decals
carbon bonnet, boot lid and gt wing
veilside dash cluster and console gauges and pedals
short shifter kit
leather interior
19 by 10 back 19 by 8 front rims and toyo tyres
full soundstream audio system and xbox 360
noz! :):no:
f*&k it, why not just by an R34 GTR NUR VSPEC II
you said dreamin right? ;)
actually scrap the leather interior, sound system, big brake kit, noz, xbox, respray and boot lid and its actually what Im hoping for, something I can take to calder friday nights crank up the boost for the street drags and turn down for daily driving, gonna take me a while though parts in boxes are starting to pile up in my garage
Edited by BOVed
https://www.sau.com.au/forums/topic/137388-future-dreams/#findComment-2584128
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
