Alright, my engine should be getting dropped back into the car Monday/Tuesday but am concerned about my radiator, oil cooler and oil pump. I am going to have around 400rwhp when dynoed, so are the any recomendations on aftermarket gear or will the standard items be able to handle it?
In case you don't already know, I have a R33 GTST S1 with the following mods:
G-Max Wheels rear: 18x9.5 with 265’s front: 18x8.5
Tein hight and rebound adjustable suspension
Full 3inch custom exhaust with Magic Cat and twin Mufflers
Ball bearing T70 turbo on X-Force highmount manifold
Turbosmart 48mm Pro-Gate wastegate
100mm think Front Mount Inter Cooler
Blitz blow off valve
Sard fuel pressure Regulator
Sard 550cc injectors
Walbro 500 horsepower fuel pump
Motec Enginge Management System (M600)
Exceedy 5 puck clutch
Pod air filter
Oil catch can
Additional thermo fan (2 in total)
Bonnet vents
Isotta Steering wheel
DBA 4000series sloted disks alround with braided lines
Braided fuel-line, blow-by, breather and radiator overflow hoses
New chrome radiator overflow tank
Gates Racing radiator hoses
Viper 790VX Pager car alarm
20thou Arias Pistions
Adjustable cam gears
Full gasket and bearing kit
Cometic head gasket
GTR rods
ARP head studs
Is this enough to keep the car from overheating?
Edit - f**ked up the hp figure.
Edited by phee
https://www.sau.com.au/forums/topic/137670-getting-high-hp-and-staying-there/
Bigger injectors, 740's is where your gonna be at now :D
Walbro - wont be upto the task either. Time for a surgetank, walbro lifter and bosch feeding the rail.
What oil pump did ya stick onto it?
And i would be using a bigger ally radiator... around $660 for them give or take
Got ducting on the intercooler?
What I mean is that air is directed into the 'core' of the intercooler and then ducted through to the core of the radiator.
The idea is to 'seal off' the gaps around the edges of the intercooler so that the air hitting it has no where to go but through the core.Quite a bit of air will happily 'wash' around the intercooler over the end tanks etc. if there are lovely gaps there as they create a relative low pressure zone. It's best if you can direct the air into the core in a sort of a slightly 'angled in' way rather than just sealing it around the end tanks.
The goal is to channel all the air into the core of the intercooler and through the radiator and then perhaps out a back facing bonnet scoop angled towards the radiator. Alternatively grabbing some washers and longer bolts for the bonet hinge you raise the rear of the bonnet so that you have a small gap at the back edge when its closed.
Make sure you do the same thing for mounting an oil cooler and always remember to have a radiator shroud for any fans you have on it, electric or otherwise.
Edited by rev210
oh forgot..
turbo beanie and thermal tape the dump pipe. If you have the coin then ceramic coat the turbo exhaust housing, dump pipe and x-force manifold and tape it as well. That will get the under bonnet temps down big time.
The pod filter is in a nice cold air induction box too I hope, with a good air feed.
upgrading the cams in my opinion is a priority. You will increase the power band a great deal, decrease the rpm needed to get boost , decrease intake charge temps due to lower restriction at the valves and reduce the needed boost pressure to make the same power if you decide to limit/cap it at 400 or whatever.
You have some very expensive supporting mods. You don't build motors around this sort of power target without changing them (cams), thats what I call a half assed approach.
you spent all your money on the motec lol.
that above list should be fine. the fuel pump will be feeling the presure.
just put anotherone in there to help it. (they can fit) and are cheap enough.
the turbo.. id keep an eye on it. to help it stay alive just do the nessesary cooldown n shit.
keep the boost to 1.1bar max and it will love ya for it :mad:
i dont see an oil cooler there? just jap have some coom serk copies for shit money. hows a 36row for 150 bucks grab ya :)
PWR radiator, regualar coolant changes header tank
Tape up any hot pipes, ie exhaust, intercooler pipes.
ANd fuel system upgrades....
These are all mentioned but that would be my priority based on your location.
I said PWR to cause you get what you pay for, PWR cores are lifetime warranty and are substantially heavier and higher grade alloy than competitors offerings this will help with heat soak!!!
Cheers
I have just finished reading the N1 oil pump thread in General Discussions, and now I bit concerned about getting an N1 pump, however I will need to get something.
Another fuel pump? As in aditional, or get rid of the one I have and buy something with a higher cc? Radiator will need to be upgraded regardless.
Oil cooler, can someone explain this a bit further?
And yeah I spent all the money on the Motec, and it came with a free R33 Skyline :whistling:
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
