Introducing Team GIRLdori!
Drift is growing in popularity not just with spectators but also drivers including those of the female kind,
Myself (silviaqueen) Cat (180_chick), Lydia (gurlrilla) and Sarah (~sarah~ aka sxkity) each
have a passion for the art of drifting and together have formed an all girls drift team; GIRLdori.
(Sarah [red s14], Lydia [white s14], Chance [black s13] & Cat [black sileighty])
Currently we're all beginners in the world of drift and together with lots of practise we're striving to master the skill.
Each of us have different aspirations for utilising our skill, be it for fun and enjoyment at practise days or
for committed participation on the 2007 Super Drift Round.
We Launched Team GIRLdori.com at Vicdrift's Practise Day this past Sunday at Winton Raceway
with overwhelming support and encouragement.
We'll be attending all Winton Practise days so be sure to come say hi and follow our progress.
Check our GIRLdori.com for more about us.
Thanx to everyone for your support, drift tips and pit work.
GIRLdori.com is looking for sponsorship; if you or a company you know would be interested in discussing
your involvement further please speak to GIRLdori Team Manager Yoshi (YogiR33)
Cheers - Chance :D
Team GIRLdori.com
https://www.sau.com.au/forums/topic/137857-introducing-girldoricom/
lol nice one Chance!
We sorta did something similar to the nomuken monkey with the superfunhappysliders g-strings ;)
turns out only a few of the girls here in melb appreciated it. :)
And LMFAO at Yosh being your Team manager... I betcha he'll get a pimp hat soon.
BTW, how's the SR20DE treatin ya? Should go the Autech SR20DE or slap some GTiR individual throttles on it and make it sing.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
