hey guys, jus wondering if anyone could give me some info on putting an rb26det into a r33 gts-t? is there alot of modifying to fit the engine? also i imagine this is an expensive thing to do?
very expensive... being that i wouldnt run the risk of using stocker turbos.
So its a 5 figure adventure.
Whats your power goal? and how much do you want to spend? For 250-300rwkw, keep the RB25, do some internal work for anything over 280rwkw (rough rule of thumb). 250 - 270 is a good figure to aim for with a 25 as you can achieve that power with little more lag than stock, and keep the internals stock. Any more than this and your up for some big dollars
If you want morepower and little lag go for a RB30DET exelent base for 300 - 400rwkw less stuffing around than a RB26 and less lag.
my 2 cents
cheers
You can only use one engine mount the left one needs to be modified to clear the turbos and associated parts. Standard RB25 box fits. Sump needs to be modified.
Drive in drive out works out to be in the 10-14g range. Ive priced it all before....
Its pretty straight forward, RB25 box will bolt directly onto the motor, you can use the rb25 loom to run the thing, IF, you convert to a single turbo setup, <much wiser move IMHO, properly selected single eg, gt30 with a .64/82 rear will be on boost earlier most likely than the stock twins> if you stick with twins you'll need to get the loom from the 26 wited in to suit, as you will need to retain the dual AFM's and o2 sensors etc..
i used stock r33 mounts to the motor with nismo mounts to the subframe, and box..
as for the sump theres a couple of optiosn you can do.. use an rb25/30/20 style sump, you'll need to bash the side where the oil pick up is, and prevent it from leaking, <slightly dodgy method> or modify the gt-r sump, by chopping off the diff housing, and cleaning it up, then welding up the holes left from where the diff passes through it, that'll fit in perfectly and clear everything..
you can also get some extended units from various places, ive had one developed for me locally by a mate of mine, will hold about 10 litres of oil, and pretty crucial if your going to be belting it on the track, if its just a streeter you will be fine with the modified stock sump..
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
