Take the car to the drags again. If your terminal speed is up on last time then no drama.
No harm in having a safe tune, dyno's are only a tuning tool.
Looking at the graph against AFR can help tell you if there is more in it to extract of course, the final number is not important. It is the change in number and it's magnitude across the graph that indicates good things.
Don't get hung up on dyno comparisons, whats the point in having a peice of paper that says 200rwkw if someone can show you one with 170rwkw for the same type of car. A that car is faster and more powerfull where it shows up and where it counts, on the track.I lost count of the number of times I've seen it and the number of people who don't get it years ago.
Just don't sweat it mate.
Well written..i guess it the knowledge of knowing whether your car is running safe and giving you the HP you need. I too don't believe in number...just want my ride to be reliable with many years of joyride left in it. Cheers!
Wot he said above, i agree!! but in saying that every1 would want their car to be making as much pwr at the wheels as possible. I would be disapointed with that personally considering wots been done. Before i put on my pod and was still running standard boost i was making 183rwkws. on my 34 now i got safc2, 3" kakimoto, pod running 0.8 and i made just over 200. Id be getting a 2nd oppinion. Just book it in 4 a pwr run, for like $50 and if ur AFR's are looking crazy on the 2nd dyno get them to do a retune and see wot it gets then. :D
Sounds about right...
Mine's putting out 186 rwkw @ .8 bar on a safe tune with the following mods (also runs 13.9 down the strip @ 100mph on a crap 60ft):
Apexi pod filter
Power FC
Blitz EBC
Front pipe
High flow cat
Cat back zorst
... running standard SMIC and turbo though and wouldn't even contemplate boosting any higher than .8 bar without a turbo that can cope with it.
Cheers.
There seems to be a bit of a pattern here, a lot of the guys that are quoting higher boost levels are actually seeing less power. This seems to indicate that possibly other things need to be changed for it to be worth while running the car at such high boost levels.
I'm not saying this is conclusive, but there is such a thing as too much boost. I'd like to know what would happen with the same car with the boost wound down to more like 10 -12 psi. Perhaps the car is getting excessive knock or something?
Also I'm not sure what pressure the intake valves can take before they start to have trouble shutting, I've heard that this can sometimes be an issue.
Personally just from seeing cars on a dyno day, of the cars that were running high boost levels it was only the ones that were well soughted out that were pulling deacent figures, all others were dissapointed.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
