Take the car to the drags again. If your terminal speed is up on last time then no drama.
No harm in having a safe tune, dyno's are only a tuning tool.
Looking at the graph against AFR can help tell you if there is more in it to extract of course, the final number is not important. It is the change in number and it's magnitude across the graph that indicates good things.
Don't get hung up on dyno comparisons, whats the point in having a peice of paper that says 200rwkw if someone can show you one with 170rwkw for the same type of car. A that car is faster and more powerfull where it shows up and where it counts, on the track.I lost count of the number of times I've seen it and the number of people who don't get it years ago.
Just don't sweat it mate.
Well written..i guess it the knowledge of knowing whether your car is running safe and giving you the HP you need. I too don't believe in number...just want my ride to be reliable with many years of joyride left in it. Cheers!
Wot he said above, i agree!! but in saying that every1 would want their car to be making as much pwr at the wheels as possible. I would be disapointed with that personally considering wots been done. Before i put on my pod and was still running standard boost i was making 183rwkws. on my 34 now i got safc2, 3" kakimoto, pod running 0.8 and i made just over 200. Id be getting a 2nd oppinion. Just book it in 4 a pwr run, for like $50 and if ur AFR's are looking crazy on the 2nd dyno get them to do a retune and see wot it gets then. :D
Sounds about right...
Mine's putting out 186 rwkw @ .8 bar on a safe tune with the following mods (also runs 13.9 down the strip @ 100mph on a crap 60ft):
Apexi pod filter
Power FC
Blitz EBC
Front pipe
High flow cat
Cat back zorst
... running standard SMIC and turbo though and wouldn't even contemplate boosting any higher than .8 bar without a turbo that can cope with it.
Cheers.
There seems to be a bit of a pattern here, a lot of the guys that are quoting higher boost levels are actually seeing less power. This seems to indicate that possibly other things need to be changed for it to be worth while running the car at such high boost levels.
I'm not saying this is conclusive, but there is such a thing as too much boost. I'd like to know what would happen with the same car with the boost wound down to more like 10 -12 psi. Perhaps the car is getting excessive knock or something?
Also I'm not sure what pressure the intake valves can take before they start to have trouble shutting, I've heard that this can sometimes be an issue.
Personally just from seeing cars on a dyno day, of the cars that were running high boost levels it was only the ones that were well soughted out that were pulling deacent figures, all others were dissapointed.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
