Hey, just something to raise an issue about.
What ive noticed is that victoria seems to be lacking small local meets. The big events are nice but some small meetup's should be organised around suburbs.
Ive been tagging along with my friend in his ozhonda club and they manage to have local meets nearly every week.
Some they have had are; late night carwashes, residential photoshoots (most shopping centres are happy for photoshoots ie. waverly gardens and monash uni) and just got back from a small meet/dinner at pancake palour at Glen Waverly
From my short time in the vic member section, sauvic seems to focus more around the large/major meets and it seems to lack the localness to it.
Im only saying this as i can only seem to find Westies and no east members floating around the board :(
Maybe once uni holidays start more local events may pop up, if not, i guess ill have to organise some.
Btw im located in Ferntree Gully area, so if any other vic member is around and interested in some form of meet up, post here so we can get the ball rolling :rant:
- Patrick
https://www.sau.com.au/forums/topic/138467-no-local-meets/
  • Replies 59
You could get some people together yourself, but our comittee runs numerous events so can't really be expected to be doing local stuff too. They already do an outstanding job of events.
Northside we occassionally have a breakfast at a nice cafe near my place, but that isn't even every month.
https://www.sau.com.au/forums/topic/138467-no-local-meets/#findComment-2578924
Thats the problem - everyone suggests it but no-one takes ownership.
But then if you really want to do local regular meets there enough other ones around. NS for example.
Thats it.
All well and good to make a suggestion, but most dont follow through.
Committee arent going to be responsible for organising mini/local meets. Its just time that we dont have free.
If you want something, do it :(
And i dunno about everyone being West... i'd say around 50% of members are all east
https://www.sau.com.au/forums/topic/138467-no-local-meets/#findComment-2579273
  • 3 weeks later...
there isnt anything stopping you guys from brain storming or even planning one! Made this thread to spark the idea of meets to be planned by any members of the forum.
If anyone has an idea post up! Doesnt have to be planned. Just state a designated time/date at the local carwash/shops/etc and get the ball rolling from there.
- Patrick
https://www.sau.com.au/forums/topic/138467-no-local-meets/#findComment-2631323
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
