  • Replies 77
oi mitchy if you buy one ill install it in for you :sick:
i did mine a few weeks ago and got it working the other night its sooo.... mad :P massive flames
dont think it will be good for the car though :)
simple as 4 wires but theres 2 wires that are meant to be the opposite to each other :S
Ive had one for about a year and used it on the street and the track
most people wire them to the handbreak for launch.
but I wired it to a clutch switch, basically it means I can keep my right foot on the floor, when upshifting, I just clutch in, limiter kicks in and cuts the revs down to 4500 or whatever, drop the clutch and be right in the powerband
whether its a benefit or not I dont really know, I dont think its nessesary
but its fun :sick:
what concerns me is whether it will cause damage to the turbo.
Ive got a nice expensive one going on and the last thing i want to do is destroy it.
Edited by midnight
  • 4 months later...
huumm okay umm please confirm this statement..
the Bee*r rev limmiter cuts the eart so random spark drops out..fuel goes out cylinder ignite and kaboom through exhaust turbine and cat...
there are 2 triggers one is the red line and the other is either handbrake or clutch.... so if I hit redline it went kaboom booom boom..
If I connect to handbrake, the moment the handbrake is lifted during driving..also kaboom boom boom..
if connected to clutch only when sudden clutch release at launch, launch control? went kaboom boom boom...
downside, damages everything in the flame's path....However this system shouldn't be too damaging unless one were to do launches and red lines everyday?
cheers
could the bee *r rev limiter do any damage to ya engine?
A friend of mine had one of these REV limiter on his 11sec street tyre REX, i think it was a UNI CHIP one. Anyway, he used for around 6 months and his pitston rings got damage BECAUSE of the REV limiter action so he got rid of it.
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
