HAve you looked at the 3.4l stroker kit? I know its a little bit more, but its good value if you can stretch a grand or two more.
By the time you by rods, pistons, rings, rod bolts and bearinigs, and balance you're around $3k - $3.5k
3.4L stroker has a new crank, rods, pistons, bolts, bearings and rings and is $5k. I think it is already balanced.
WHen you think about it, $1500 really isn't that much more for a torque monster. Plus you wouldn't have many lag issues.
WHERE the f**k u getting these prices from.... $3k for rods, pistons ect.... what are they beryllium ?? or are u buying these and adding on the miner tax ??
well..I just checked and the prices have dropped a little since i looked last. But pretty close..
GOOD Pistons & Rings $1400
Spool Rods: $700
Rod Bolts: $200
Bearings: $200
Balance: $400
Crank Collar & Fitted: $200
Total: $3100
Crank journals \ Block tunnels might need machining - $possible $500 - $1k depending on what needs to be done..
I'd even get the crowns of the pistons and the combustion chambers HPC'd. Price isn't too bad. Just need to balance after this is done.
3.4 Stroker, with all of those parts, already balanced with a brand new crank that is capable of high revs, is only $5k..
Then buy a GTR one day and transfer this bottom end to it... lol
To me it just seems like a better buy and more piece of mind.
I want to stick with the RB25. For what I want it to be, anything over an RB26 is useless. I'm not a racer, drifter or anything. Just want a safe motor and tune that has some balls that MIGHT have a chance against a SIL80 that will be around the streets shortly.
http://www.spoolimports.com/spool-engine-rebuild-kits/nissan-rb25det-rebuild-kit
Nissan RB25DET Rebuild Kit
This Rebuild Kit includes the following quality parts:
  • SPOOL Forged H Beam Conrods
  • CP or Ross Forged Pistons (Rings, Pins and Locks Included)
  • Cometic MLS Head Gasket
  • ACL Race Series Main Bearings - STD & 0.25mm
  • ACL Race Series Big End Bearings - STD & 0.25mm
With Ross Pistons - $1990
With CP Pistons - $2090
the rods come with bolts already dont need to buy 2 lots
She'll be a screamer. Can't wait to hear it on gate, haha. I don't know who is tuning it yet, he hasn't told me I don't think. But deadset, the turbo on it is going to suck small children in if he drives past a school or even a pregnant woman.
That's the kit I was looking at. Want to keep 2.5L, but the reality is that even the $2,000 for that is out of reach at the moment when im paying off stuff, saving for a house and saving for an overseas holiday on apprentice wages. The 33 is taking a backseat to more important things at the moment, but one day I'll get a rebuild kit, spray and tidy up the engine bay, and make the engine look pretty like my VL RB30
Then it will be 24psi of HKS fury pumping into that engine haha
is 24psi where the efficiency runs out ?? ur talkin bout the turbo u got on there now ay ??
im gonna hate goin back to apprentice wages :(
HKS GT2835 KAI
Bit of a let down ATM but trying to work with HKS to work it out
243rwkw @18psi
But I think I accidentally knocked the timing back a bit when I put my new timing cover on. Will check that and then see if it feels any better
Edited by 89CAL
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
