HAve you looked at the 3.4l stroker kit? I know its a little bit more, but its good value if you can stretch a grand or two more.
By the time you by rods, pistons, rings, rod bolts and bearinigs, and balance you're around $3k - $3.5k
3.4L stroker has a new crank, rods, pistons, bolts, bearings and rings and is $5k. I think it is already balanced.
WHen you think about it, $1500 really isn't that much more for a torque monster. Plus you wouldn't have many lag issues.
WHERE the f**k u getting these prices from.... $3k for rods, pistons ect.... what are they beryllium ?? or are u buying these and adding on the miner tax ??
well..I just checked and the prices have dropped a little since i looked last. But pretty close..
GOOD Pistons & Rings $1400
Spool Rods: $700
Rod Bolts: $200
Bearings: $200
Balance: $400
Crank Collar & Fitted: $200
Total: $3100
Crank journals \ Block tunnels might need machining - $possible $500 - $1k depending on what needs to be done..
I'd even get the crowns of the pistons and the combustion chambers HPC'd. Price isn't too bad. Just need to balance after this is done.
3.4 Stroker, with all of those parts, already balanced with a brand new crank that is capable of high revs, is only $5k..
Then buy a GTR one day and transfer this bottom end to it... lol
To me it just seems like a better buy and more piece of mind.
I want to stick with the RB25. For what I want it to be, anything over an RB26 is useless. I'm not a racer, drifter or anything. Just want a safe motor and tune that has some balls that MIGHT have a chance against a SIL80 that will be around the streets shortly.
http://www.spoolimports.com/spool-engine-rebuild-kits/nissan-rb25det-rebuild-kit
Nissan RB25DET Rebuild Kit
This Rebuild Kit includes the following quality parts:
  • SPOOL Forged H Beam Conrods
  • CP or Ross Forged Pistons (Rings, Pins and Locks Included)
  • Cometic MLS Head Gasket
  • ACL Race Series Main Bearings - STD & 0.25mm
  • ACL Race Series Big End Bearings - STD & 0.25mm
With Ross Pistons - $1990
With CP Pistons - $2090
the rods come with bolts already dont need to buy 2 lots
She'll be a screamer. Can't wait to hear it on gate, haha. I don't know who is tuning it yet, he hasn't told me I don't think. But deadset, the turbo on it is going to suck small children in if he drives past a school or even a pregnant woman.
That's the kit I was looking at. Want to keep 2.5L, but the reality is that even the $2,000 for that is out of reach at the moment when im paying off stuff, saving for a house and saving for an overseas holiday on apprentice wages. The 33 is taking a backseat to more important things at the moment, but one day I'll get a rebuild kit, spray and tidy up the engine bay, and make the engine look pretty like my VL RB30
Then it will be 24psi of HKS fury pumping into that engine haha
is 24psi where the efficiency runs out ?? ur talkin bout the turbo u got on there now ay ??
im gonna hate goin back to apprentice wages :(
HKS GT2835 KAI
Bit of a let down ATM but trying to work with HKS to work it out
243rwkw @18psi
But I think I accidentally knocked the timing back a bit when I put my new timing cover on. Will check that and then see if it feels any better
Edited by 89CAL
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
