Yeah something I should have checked but oh well lol
I have a different front cover on mine to standard to block the anti surge slots off. Think this loses alot of flow when the standard anti surge holes are in there. It's not a big enough Turbo to warrant surge slots IMO and provides more cons then pros
Its much nicer to drive with my front cover on, fixed a few small issues. But it's not a great "fix" at the moment. Was hoping HKS would give me a Pro S front housing to try as I think this will improve it
But anyway, it's good enough for now
hmmmm, interesting. Though I've never done much reading on the 28's etc with anti surge etc to know pros and cons, but it's a bit of a strange one it would be better with it blocked :O
I had the GT3076 or the "GT3037"
0.6 Surge slotted comp cover
0.63 rear housing
Put the 0.82 rear housing on when I switched to the RB30.
I found the surge slotting was ok, especially when I had the BOV removed for a short period of time, and when in higher boost the factory BOV couldn't keep up and it created reversion.
Would have loved to try a non surge slotted cover, but I have heard stories of the surge slotting allowing more air in further down the blades, allowing the turbo to spool faster. Wouldn't have a clue if it does or not though, its something you'd have to try yourself.
Callan, what is your lag like?
On the RB25 I had 18psi by 3400 in third
On the RB30 I had 18psi by 3000 in third, maybe earlier. Hard to tell it moved that quick.
Surge holes like this?
The port shrouding on the Pro S housing is more typical on a turbo of this size. By the time the air has reached the rear of the surge slots there is some pressure there. And the other end of the holes are on the suction side of the turbo. Long physics lesson short, high pressure always wants to go to a lower pressure section. Pressure difference = flow. So therefore there will always be flow lost that would normally go into the engine that is now being recycled back through the blades
This is how I understand it anyway, what I know about physics makes me think I'm right and Stao from hypergear originally told me it would be the anti surge slots that are the issue. On a T04Z there is a benifit as such a large air flow might result in some surging. But a small GT30 series doesn't flow enough for me to think anti surge slots necessary.
This is what ive done
But as there is no actual seal in the snout of the Turbo to the housing, there is more then likely a leak between the two, again this will mean a slight loss in flow
This is how I See it anyway, hypergear will make me a new housing but want the whole turbo. Seen as it is my daily, I need the car so this isn't really possible right now
yeah thats the whole idea about the anti surge housings.
but i wouldnt think it would make that much of a difference.
its only if there is too much pressure so its squeezed out these holes.
i thought there was 2 blades on these turbos and the holes go ruffly to where the 2nd blades are.
maybe not and they are on the pressure side but then wouldnt it just be working twice as hard ??
air would be recirculating no ?
My 180 will be in Mky soon. It goes brum.
nice ride. gl wit it.
:lol: jokes this isnt boost.
Callan, whole heartedly agree with what you have to say about anti-surge. it is a good talking point really. ;)
I've heard about this sil80
Word is it's packin' heat! And getting tuned by mackay's finest?
you should be more worried about the 1 up your way.:P
i've heard a few things about the 1 your talking about, apparantly the owners mad c&*t :wave:
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
