I think I know a little about this car. If the plates are still on the same car that is. But there was a blue r34 in Adelaide with these plates in around 2003. It was stock engine and turbos making about 260awkw with an exhaust and power FC. So yeah I would really doubt the claims of it being a 2.7 built in Japan!
I heard back from the guy with the SIL80 last night. He's doing the KA24 with twin TD06 turbos now. Insane?!?!
sounds like it will be a weapon for sure... wonder if he will let me have a look at it when its done
What ECU do you run, Force? Or just a standard?
I'm still waiting for Dysonest to get his ass over here and help me decide on what I want.
But yeah, apparently the RB26 D'Jetro splices pretty simply into the KA24 system. Almost nearly just plugs right in.
Actually, I even modded one to run my mates r32 gts-t and it was still simple. Barely any cutting or soldering.
the mafia is deffinately the person for the job by the sounds of it
Keep it up, you can pretend that you are cool. But you really must fail at life. I'm glad constantly trying to be cool on a forum makes you feel a little bit better about it.
If I wasn't such a calm person, I would have ended up punching you in the face by now if I knew you or met you. But, instead I'll just feel sorry for you needing to make up for your shortfalls.
Good luck anyway. Your mouth will catch up with you, not all people are smart enough to control themselves like I can.
Edited by The Mafia
Reminds me of a mackay guy that said his RB20 was a forged 2.4 stroker. Sold it as that too. Engine died and my mate obtained it for parts. Was a 100% stock RB20. NOt a single bolt touched on the engine. Probably not even for servicing.
Powerfc mate L-Jetro, Will be getting removed and swapped for a Haltech Platinum Pro plugin at end of year. Needs the nismo AFM's if I wanna push the turbo's to their "potential" without issue..... or I swap to ecu with MAP sensor.... :)
Depends on who you want to tune it mate and what your needs are really..
Yeah, I've heard that too! LOL
Trained for 10 years. I think that's enough for me.
But you're just a smart mouthed dickhead that has read a few forums. I bet youve done f**k all actual modding. If any at all.
I don't know what you're trying to prove either, you keep coming back here. Must have a boring life.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
