yea i think your right there, just putting cash aside now for t400 auto box and trans brake so im expecting to break diffs and axles more often when i get it all in the car. i found billet axles for my car rated to 1000hp for 550 delivered so if i break them again ill just upgrade. diffs i have just not axles.
Are they for Gts-t cause I only ever find GTR ones which I assume are longer?
Debating wether it's better to have the driveshafts as the weakpoint or not cause if I get stronger ones it's only gonna be something more expensive that will break instead......
Driveshafts should not break if the suspension is setup properly, the only other way they will break is fatigue from doing a million launches in them. If you have have really hard spring rates like 7-9kg/mm on the rear well that is way to hard, and if your car gets axle tramp when the wheels spin well that will also cause it to be weaker. Personally i don't know if GTR shafts are longer than GTS ones but i'm gonna guess and say they should be the same. If you are gonna be drag racing the car all the time then its probably worth spending some coin on the rear end suspension getting it right so when the car squats for a launch the driveshafts are as straight as possible. + dumping the clutch at 6000-7000rpm is not good either as this shock loads the whole drive train, in GTR's when you dump the clutch at 8000-9000rpm all the time i guarantee you will end up breaking something really quickly, need to side step the clutch by releasing the pedal slowly and letting the clutch grab slowly it might just save the drive train a bit of shock load. I see people all break shafts all the time, i've owned skylines and GTR's now for 6yrs + and have never broken a drive shaft yet and i thrash the shit out of my cars ask Kingy he can concur with this lol thumbsup.gif.
Haha yeah. I think my driveshaft that snapped was a bit of a random thing. Ask anyone I don't really do hard launches around town, I'm a girl and all that shit yeah yeah :P
But it's always in the back of my mind now, I'm mainly worried about if I ever get semis. But I need to slip the clutch a bit next time I go out for a run. The button clutch won't make it easy but I'll manage :)
cal, I did stacks of drags and launches and stuff, and with semi slicks and never had an axle problem. I think your problem was a bit of a fluke.
Also, always let the clutch out, never side step. Too much shock, and you'll only create unwanted wheelspin.
Does beat the shit out of it..... When its not parked up being worked on lol...:P
Ben, would t waste your time with the dirty thirty.
You're better off with the dirty whore, thirty four. Haha.
The rb30 cranks are a bit old to be spinning hard. The rb34 kit from spool has a billet crank in with the package. Costs $5k. Spin the f**ker to 10k and bolt twin gtx3071s on it, haha.
You need to set the record straight with the xr6ts ;)
Ah i got 2 RB30 blocks at home a shitty N/A block and a Turbo Block, should just sell them and spend it on my N1 engine or sell the lot and twin turbo the Z, hhmm never own 2 good cars it just makes it harder to figure out what to spend the money on.... someone buy my GTR i'm sick of looking at it.
the NA blocks are just as good as the turbo blocks (exactly the same) if they are a series 2 block. They have the oil and water lines for the turbo. Just bunged up.
I'd use one for the RB34 ;)
How long do you think Cals engine would last with the TO4Z on it? haha.
Lol Stock RB25 with T04Z = LAG MONSTER i'd give a week before it would blow a piston and rings to bits rolleyes.gif
I remember my mates R34 GTT i built for him with a GT3540 on a stock engine, damn that thing had bulk lag but was awesome fun on boost.
Seen an RB25 with a T04Z (all be it not as new design as the one you have) and yeah..... No thanks lol
The only reason I went HKS was for good mix of power and response, would have been more then happy with the Pro S. I'm sure of that
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
