Holy shit i can't believe how quick all my parts are selling, i must be selling them to cheaply lol. Hopefully everyone comes through with the money i'll be rich as motherf**ker teehee.gif!!!!!!!
haha you'll be richer tomorrow when you see your bank account ;)
Do you have any standard GTR Rims? I know kingy has his standard R34 rims. I have a mate that wants to buy a set of 18s. He's got a full race spec GTS-T with a 25\30 in it.
Was funny, he was racing one day, and the water pump shit itself and dumped a heap of water as he went through a fairly paced corner. Sent him doing 360's off the track. Lucky he didn't hit anything.
Haha cheers man, the only rims i have for sale are my 57F Pro Titaniums 18x10's and my Standard 350Z Rims and Kingy has his BBS 18x9.5's.
Lol i've seen a water pump on a RB25 snap the whole front of the pump cast housing and the fan went threw the radiator and i was like WTF happened here, lucky i had a spare radiator to give him.
Im thinking about getting the front lip on my car carbon fibre wrapped, and maybe the grille as well.....
but im not sure if it would look any good, I keep changing my mind about it lol.......
opinions?
Not sure it will fit Ben. The S2 headlights are different to the S1 GTS-t and GTR lights. I couldnt fit my S2 grille in when I still had my S1 front on from memory
Happy to try it if your in town and have it on you but lol......
Ah yeah forgot you had series 2 Cal probably won't fit then.
Got T'N"T tonight hopefully our shit rocks up in the mail today for the 32, i tell you what ANDRA have some of the most bullshit rules to comply with like this one is a classic example only came in last month. Any Manual Gearbox Car running quicker than 11sec must have a Steel bell housing for the gearbox. What f**king load of shit, we are still waiting to hear back if our car will pass the inspection, we got Mark to overnight a Kevlar scatter bag for our gearbox, hopefully they will let it pass otherwise we have to pull the gearbox out and try and make one talk about getting f**ked around. And also we had to change all our wheel studs cause standard one aren't long enough. The list goes on ready to kill some flamin mongrel if anyone gives me shit out at the track tonight i'm gonna headbutt the shit out of them, gonna run a 9sec pass tonight on the 19's then i'm gonna rub it it to all them f**k wits who said our car couldn't do it they can all eat shit and die!!!!!
If I ever sell it, it's a genuine series 2 as well ;)
Not sure about TNT. Won't be racing anyway, haven't had time to check my base timing and go over the tune again. Might come watch depending on who else is going
Drags are on today again qualifying starts at 12 and racing at 6, had a good night last night. first run of the night was a 10.1sec @141mph with a 1.5sec 60ft the other two runs where wasted as my brother was trying to flat shift but the gear gearbox thought otherwise still got a 10.4. Parachute worked well but still having bulk traction issues hopefully they put some of that sticky VHT on the track today and we can push it into the 9's, this will be they last event where we are gonna run the 19inch advans gonna order some Mickey Thompson's probably next week. Maybe the hot sun on the track will give us some better traction. Will put videos up tomorrow. thumbsup.gif
Nice work, so close to a 9 you can almost taste it. Think if they throw some sticky stuff on the track they usually do it before test and tune but hopefully I'm wrong and you will have a better chance of cracking a 9 tonight :)
Well done in any case, any improvement is a good thing :)
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
