Why not tell us the name of the workshop so if one of us go in there we can ask for them to do the work and not a contractor? Saves us money as well.
I need to stop being lazy and fab shit up for my car... And Force Feds. When he gets his ass down here.
MHE are usually pretty good and old Ben, if he is still at Mackay Alloy, is amazing on the alloy TIG.
AluFab (or AIS I think it is now) do some great work as well. Dad had them make a new piece for a fender made and it was a great quality product they produced, just by having the damaged one as a base to.
i herd ashton is alright haha... nah if i need anything done ill either do it myself or let my old boy do it, he goes alright with a flint rock
Ashton is by far one of the best. Pity he doesn't do the performance stuff anymore.
Never seen someone so quick, accurate and neat.
Oh and dyshonest - I think you stuffed up there, you've bolted the turbo onto the wrong side...
Edited by The Mafia
ha ha ha ha ha ha ha ha haha!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! oh mafia how you make me laugh, dont stop these great post your doing. you are joking righ? wrong side oh your killing me ha ha ha ha ha ha!!!!!!!!!! YEA DYSONEST YOU WANKER GET IT RIGHT ha ha ha ha :domokun:
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
