umm if i was to put the turbo on the other side i would look like a f**kin dickhead..... and so do u for making that comment haha
annyyyy way. yeah ben i have worked on both too and everyone knows toyota's are built better / smarter in every way devil.gif
Well if it was a Nissan the turbo wouldnt be on the wrong side... But, I guess someone ie Toyota has gotta be different and homo and put the turbo on the wrong side... Lol
But I agree, the Toyota has a lot more thought put into it. Geared oil pump drive... 12x 14mm oil drains as opposed to 6 x 8mm drains etc.
Edited by The Mafia
Better built, but everyone loves an underdog lol
One of the reasons I never skid = axle tramp. Shook the sunroof controls from the roof it was that bad.
Hopefully will be getting much better launches when i head back out to the drags
Turbo landed in Australia during the week. Should have it an the wastegate by Tuesday. Bulk carbon parts from Phil, full kit, mags, internals, manifold is being fabricated at the moment. Got some HKS goodies as well.
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
