sorry should i say tail shaft. not the 5 bolts from the half shfts to the diff i have those just need a new set of tail shaft bolts.
No go from Nissan? If you want I can look some part numbers up when I finish work today
Look what i found today:
f**k U RUST !!!!!!!!!!
Not to worry that shit is fixable.
Ordered most the bits i need to finish my engine off today just to seal it up and keep the dust out and have it ready, i have decided to top mount my turbo just to make my life a lil bit easier, just waiting on a quote for exhaust manifold dunno which to get 6Boost or FULL RACE.
Purchased:
-Genuine Nissan Timing Gear Overhaul Kit
-Billet Fuel Rail
-BC Adjustable Cam Gears
-ATI Harmonic Balancer
-All new seals and Gaskets
-0.61 External Gate Turbine Housing (had 0.86 internal gate)
-Nismo Thermostat
Still to get for engine:
-Exhaust Manifold
-ID 1000cc Injectors
-Turbosmart 45mm Wastegate
-Turbosmart BOV
-Turbosmart FPR
-Plazmaman 60mm Throttle Body.
-Mishimoto Intercooler (V mount)
-Mishimoto Radiator (V mount)
-Mishimoto Oil Cooler
-Vipec V44
-Super Spark Coil Packs
That should be it lol.
any one got a spare set of drive shaft bolts, from drive shaft to diff? the 4 bolts nuts and washers. ant help would be good thanks lads having trouble tracking them down.
why dont u go to a bolt shop and get some ?? 8.8 hi tensile should be fine, split washer n nut or just a ni-loc nut.
from memory they are about an m12... may be wrong there, n about 30 to 40 mm long ??
Def not M12
There about 8mm I think from memory.
This is what I found if you want to go to Nissan
Part number is shown in the background window, corrosponds with the codes on the picture. Anyway, should be able to work it out lol
Yep, i wonder why most of the Skyline owners in Mackay don't join this forum. Been seeing more and more lately, think there's a new white R34 GTS-T ( i think ) green p's only seen it once.
Edited by Seano350GT
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
