I'll see how I go, Haven't touched the sump yet, it still needs a fitting welded into it for the oil drain but I have to clean the thing first, its a mess and full of sludge etc.
Have to work out whats happening with the Intake cam. I have one cam cap that stops the cam from turning, another one is a little tight but the cam still spins, other then that it spins beautifully. Exhaust cam is fine, so not sure how 1 out of 14 cam caps is so bad. Not sure what I'm going to do about it yet
Just talked to the guy I got the head off, said the cam caps might have got mixed up which would explain why I have 2 that are tight, look offset towards the intake side a little, so hopefully he can find the othes otherwise the caps will have to get skimmed and line bored
I'm about 90% sure that they are stamped with numbers so it shouldn't be too hard to get the right ones.
It really sucks that they were mixed up though, that's a big no-no, makes the head neary useless without expensive machining.
Oh yeah, they are all stamped with their position. But I4 and I2 are tight and the guy I bougth them off had two engines/heads apart at the same time so hopefully they just got mixed up from 1 head to the other and he can find them, will be the easiest and cheapest fix.
These things happen but, I suppose when the time comes I'll have to see whats cheaper - a new head or line boring mine
Got some Nissan bits today, nothing to exciting but necessary all the same.
Had a play with some wrinkle paint today:
Think I'll go with this on the intake manifold, but think I'll just keep the cam covers a flat paint job.
Where did you get the wrinkle paint from, Callan? I gotta paint my plenium and covers too. Any variaty of colours?
I got black wrinkle paint from repco (auto barn was sold out of black and only had red) these are the only two colours I saw. I just did the wrinkle black and then painted silver engine enamel over the top. Hopefully the Plenum will look like a genuine Greddy when I'm done
Why Hello:
Things seem to be coming together all of a sudden, instead of one problem after another lol. Going to work out the compression ratio in the next few days. Going to be alot of screwing around to work it out but I guess you get that :)
Ordered my Hypergear turbo today, looks like it will shoot over 300rwkw on 98 and 350rwkw on E85 (when that gets here) but its a pretty experimental turbo at the moment so just have to wait and see. But I think I'll be less disapointed then i was with the HKS Turbo I'll put it that way :)
6boost jake.. they do hi mount aswell. i can source a high mount similar style and quality for around 850 for a 20/25
A 6boost for that price? Or just same style?
Well I'm after a new head now. Going to be too much hassel to fix up the 2 cam caps that don't match
Can never be to sure :P
someone told me before I bought the 6boost that It should only cost 850ish but I had to pay more, so was wondering if I was just looking in the wrong places
6Boost have never been under $1000 to my knowledge
Has anyone else seen that grey GT-R getting around? I've seen it twice now, 1 time just north of the Forgan bridge then the other at night on Slade pt road.. I have a feeling it lives at Sladey. My god it's sexy.
I'd be after a lowmount for a rb25det but need to save some pennies first...
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
