Indeed, but i'd never seen one in the flesh. Pretty sure it was stock standard, it had the LED's at the front which i'm not a big fan of so i think it's a 2009-2010 don't those years have the LEDs?
So nice but!
35 Sexy?! If your into fat chicks that are really, really good in the cot. But whatever floats ya boat i spose :P
Tell me you wouldnt have this:
There are prettier cars that have come out around the same time as the GTR, but there still a nice car :)
Yeah I'd have that and sell it to buy a 34 ztune, resprayed in midnight purple 3. Or even a de-stickered mine's 34. 35's are like the half decent looking fat chick you take home after being knocked back by the hotties. But if money really was no option, the original maclaren f1. In silver. Side profile looks like a silver .223 round, should be hunting down werewolfs.
Just had a thought now driving past Caltex Nebo road. They are ripping everything out of the ground there. Are they bringing E85 here?
Or did they have a cracked tank etc and are just doing boring maintenance?
From whst I've heard, they are just renovating and putting new tanks in. The only service stations that have been intetested in E85 is the BP and Shell at the city gates. Only because of Palmyra's location though.
E85 is 85% ethanol and 15% petrol, octane will be over 100 and the ethanol is good for running more boost and timing a bit more detenation resistance the Sucrogen E85 we use in the R32 is more refine with better quality petrol it is 109% octane. Down side to E85 is you need bigger fuel system with better flow and it burns up nearly twice as quick as petrol so if you average 500km per tank on Petrol you will probably get 250km a tank so your range is halved
On a 600 hp 25/30 I can still get 400 kay to a tank on pump e85. Octane rating is 104,
driven sensibly (stay off boost) fuel economy is sweet fa different to 98 unleaded, Its only when you open the tap that it starts to drink like a sailor.
If you have it available just use it. your engine will run better, plugs last longer and it smells like a rum distillry, (i like that)
This is where I can help - Chemistry was one of my strong areas at school. Always had an interest in it.
This is a Ethanol Molecule: ethanol_molecule2.png
This is a Heptane Molecule gasoline_molecule2.png(The most common molecule in gasoline)
As you can see, there are a lot more Hydrogen and Carbon atoms in gasoline (These are called carbon chains), so technically you'd need 2 x more ethanol molecules to take up the same amount of weight as Heptane is twice the weight. You should see diesel - its twice as long again.
When you add oxygen (o2) with Heptane, compress it and add a source of ignition, the carbon chains break down via a chemical reaction and re-forms into co2 +h20 + energy (and lots of other nasties due to the additives in the fuel). The reason these chemicals do this is because of electron shells, and wanting them to be full and stable. (Electron shells are another whole chemistry lesson, haha)
here is stoichiometric: e89086732554dcad6ebf9985bbf9e4d8.png or simple terms - e23da01758c21d69beb68f71f2a10097.png (Thanks wikipedia)
This is is a fairly simple maths equation. If you count the amount of carbon atoms in the Heptane molecule it helps you understand this equation better. You can work out how many oxygen molecules are required to burn a molecule of heptane. If you did chemisty you would have learned this back in school! haha.
Anyway, ethanol is more interesting in the way it reacts with oxygen under pressure and an ignition source.
Ethanol -> C2H5OH(l) + 3 O2(g) =Heat=> 2 CO2(g) + 3 H2O(g)
Gasoline -> 2C8H18 + 25O2 ~> Heat=> 16CO2 + 18H2O
Ethanol being smaller, having its own oxygen molecules, and being more "chemically satisfied" means that you can compress it more, and with that extra heat due to compression it is more stable and less prone to becoming unstable and reaction on its own without control (detonation). The extra oxygen molecules also help it also burn cooler. It also produces more energy so the idea of using double the amount on light loads isn't entirely correct. There is an exact way of figuring it out but I CBF'd doing the maths right now. Once any engine is on heavier loads, power starts to simplify and mostly rely on the amount of fuel and oxygen that can pass through, and efficiency.
In a nutshell, you can cram more Ethanol into the cylinder because, meaning you will use more, but you will also make more power. If you can't make more power because of engine \ airflow \ other limitations, then you won't use more.
The consumption is really based on power output. For example - Bennys GTR would chew the shit out of it because its making bulk power :)
There is much more to explain and I'd need hours and a white board to explain but this gives you a good idea of the differences. Google also helps a lot if you're looking for information on the chemical reactions.
I love E85 and the chemisty behind it and I wish they would replace all bowser fuel with it as its much better for the environment, and our precious engines. Oh, and there is almost no soot!
To the people that don't know me and make up shit like I read a few magazines to learn how to tune (They know who they are) and think they are cool posting lies on facebook, keep living in that muppet \ sheep lifestyle of not having a clue. I'm more than happy to see you burn money on tuning elsewhere. I'm 8 years into tuning and my friends \ customers are quite happy with the results.
To the rest, give me a call if you have any questions, I am more than happy to help :)
Edited by The Mafia
Hahahaha. No post was aimed at you. People who commented on it made it about you. Get over yourself.
And lets get some facts right... There are a few of your 'customers' who have not said a good word about you at all. Enough is enough. Stop blowing your own horn. You don't see other tuners preaching about themselves, do you?
You tell me to get over myself, yet there is nothing for me to get over. You are the fools trying to prove some bullshit point. I'm simply confident in my work.
And dyshonest, the man how winds the f**k out of his timing, blows the f**k out of his head gasket, and then sells it to some poor unsuspecting person as a perfect engine... Then bags me out as a tuner. oh the irony.
I'm astounded at the "dyshonesty" alright...Was a dog act. And you're his sheep, you and your Chris mate.
its ok, good for you.
A few of my customers? Let me guess, Blocka, and the Ebay turbo that wouldn't make power beyond 200rwkw because it was a peice of shit, proven by 2 different tuners? I can't help it if people get scammed and buy shit that won't produce the flow. Good for you though. If you want to talk about mis-informed shit, thats your problem I guess. You're a sheep.
Edited by The Mafia
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
