Onto a different topic,
Food.. I just ate possibly the best kebab in my life.
Don't know the name of the shop, but it's next to the fish market shop and across the road from Subway at north mackay Evans street. Also near Pedders. Holy shit it was amazing.
I don't know man but they use like a The land of goat sphincter rings bread sort of wrap. SO tasty, farrrk.
WTF ^ it won't let me write T-U-R-K-I-S-H LOL
Edited by Seano350GT
10-12 hrs a day, 6 days a week for the last ten years.
What's an RDO?
Then putting up with shitheads making ol' peter griffin photoshops and gtir's.
I'm shocked Kat hasnt beaten you up yet! :P
Time to buy a new box. Starting to lose 3rd, can't change when doing above 5500rpm in 2nd.. won't go in. 5th gear still grinds. Sourcing new and upgraded box from the later model 350z's with stronger synchro's for about $1900 delivered. Then clutch & flywheel about $800. 5 hour-ish labour from my mechanic.
Would a 370 box fit? Or even an RB25 box with a conversion plate?
u mean my car? i'm really not sure, i have a feeling only the 350z's and V35's with the VQ35DE motors will fit, i think the VQ35HR motor started in 05 with the new tranny.
350Z gearbox are weak as shit just like SR20 gearbox. Depends on how much power you want later on in life, $1900 for new box, shit man just pull it out and tear it apart put new syncro's in.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
