Thanks Sean, I will make another call. That dude must not have been too interested in selling me a car..
Jono,
Either call Ben or Vas, i had Ben over at my yard yesterday i told him i had a mate keen on an 86 he said there's one here to test drive but the wait is currently 3 months for the base model and 2 years for the GT-S or whatever the one is with the bodykit and spoiler.
Ben - 0400 422 628
Vasili - 0400 251 725
They will both help you out man.
Thanks mate, as soon as I get a chance I will organise something with one of these guys.
About oils earlier too, A mate sent me an interesting test of all oils. Seems Royal Purple and Penrite seem to be the best in these particular tests.
http://www.users.on.net/~pacey/sau/Oil%20Tests.pdf
Anyone know anyone who wants some of this stuff.
For Sale:
SR20 Forged Bottom end Package Used but in very good condition.
- Eagle Forge I-Beam Rods with ARP Bolts
- Venolia Forged Alloy Pistons measure 86.5mm
- Stock SR20 Crank has ACL Bearings but should be Replaced when rebuilding engine.
Take the lot for $700 ono
BENNY BOY THESE ARE H BEAM RODS MATE :domokun:
I think once i'm finally off these P plates i'll look for a tidy S15. Seems to be a shit load of SR20 bits and peices reasonably accessible and cheap rather than turning the V35 FI or throwing a Vortech on it.
thats why u mod cars lol... to be different. in saying that if u dont wanna spend BULK cash then yes lightly mod an S15, theres parts everywhere for them
Yeah there isn't many V35's in Aus that are Turbo'd or Supercharged so it would be interesting, but the only real downfall with my car is that there isn't a lot of people in the country that know a great deal about them and parts almost always have to be sourced from Japan/USA.
I still have 12 months.. so i got plenty of time to decide!
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
