Starting at Hyundai in new cars next Monday and i'll have a demo car from the get-go.. also moving house tomorrow and will not have anywhere to put my car other than in the street. Figured i'll sell it and save the money i'm paying on loan/rego/insurance and grab another car in 12 months once i've got rid of these P plates and hopefully then i'll be in a place that has a garage of some sort. love this car so much but it's just not worth it when it could get damaged sitting where it is and paint fade/weather damage and not to mention it'd hardly get driven. I would rather send it off to someone that will take care of it.
Edited by Seano350GT
Whilst it may not seem too great now Sean at least you can put a bit of extra cash away for the car you really want and drive around town in a company car for free in the mean time!
Looks like a JUN 2.8 kit will be making its way into my parts collection shortly! :)
Mustard = $50 note.
I'm implying that I'll buy your car for $100 :P
smart ass.. aha
Whilst it may not seem too great now Sean at least you can put a bit of extra cash away for the car you really want and drive around town in a company car for free in the mean time! Looks like a JUN 2.8 kit will be making its way into my parts collection shortly! :)
Yeah absolutely man that's what i'm thinking about now. Who knows maybe by this time next year i could afford a GTR of some sort..
Yeah I'm looking at getting another R32 GTR sometime next year probably cost me 20-25k for a good condition one. Or either a front cut and build my engine first.
You will need a good shed if you own a GTR Sean because it will need lots of attention no matter what model you choose.
Sent from my iPad using Tapatalk HD
Not if you can resist the urge to modify it :P
33 GTR should be pretty good
Get an FT86 for cheap, turbo the engine, fit nice rims + Suspension.........
Just sayin :)
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
