hey guys,
i have a serious problem with my rb25det as i have recently installed a greddy type intake manifold and a HKS exhaust manifold where the turbo mounts at the bottom of the extractor. With these new installements into my engine, i have maintained my standard turbo and an external wastegate which is fine so far. my problem occures at cruizing speed in fifth gear. i'll have my rpm below 3000 and as i gradually lean deeper into the accelerator till full throtle and the rpm is building fast towards 6000 and i'm pushing full boost of 0.9 bar, i will suddenly have a power cut from the engine. there will be a 2 second wait till my engine actually decides to start pulling with power again... what could this be???
i suspect that the air fuel mixture is not right maybe i leaned out too much or could it my ECU (standard by the way) going into limp mode as i detects some error? is it a fuel cut or is my fuel pressure not enough? i'm currently pushing 60 psi of fuel though my sard fuel press regulator. i'm also running a 280lph fuel pump and an external wastegate with a HKS pod filter. standard injectors, ecu, cams, and cam pulley, standard rb25det throttle body as well. i have gone mad trying to figure out what the problem is and i have exhausted all possible suspects short of getting my car on a dyno and upgrading my ECU. so i hope someone in this forum could come to my aid.
i have not experienced this problem in any other gears accept maybe once in forth but it always happens in fifth gear.
https://www.sau.com.au/forums/topic/140003-rb25det-full-throtle-problem/
60 psi is a bit too much - standard is around 37 psi, rising to perhaps 50 on full boost.
So, the engine will be running richer than normal, and I've heard recently that too rich can also cause knock.
Try backing off the fuel pressure a bit.
seems to sound like what yours is doin, happened to me
i changed to a pod air filter, and cause it wasnt tuned for it, as i gradually put my foot down in fifth, as boost came on , it starting hesitating.
Have ya tried doin it putting down your foot in fifth with just standard boost (6psi). And see what it does.
But i think ya pretty much right, after changing ya intake manifold, there would be a different flow of air changing your air/fuel mixtures.
And the standard ECU doesnt recognise it.
Would like to know what it is
If i was in your position i would be savin for a PFC, and a tune.
If you are located in Brisbane i know the best place to go.
5th gear, approaching 6000rpm.
Standard ecu.
This would be at speeds right around 180km/h wouldn't it?
It might be the 180km/h cut out you're experiencing?
Then again, I might be totally wrong...
-Insu
That's what I was thinking.
Where are you doing 6k in 5th?
Yeah I was thinking it was a bit high, but he does say 'approaching' 6k.
So yeah, just a thought.
oh ya guys.. i have to tell yall i have gone to 250kmh on my car with standard boost before... i have a speed cut chip already installed. :laugh: sorry to have left that out :no:
one more thing is that i have started to notice the problem presisting on 3rd, 4th and 5th gears now that i have lowered my fuel press to 55 psi. the possibility of having turbo overboost keeps coming up as suggested by mechanics as i explain my problem to them... what the hell is turbo over boost??? i am only boosing a max of 0.9 bar on my rb25det stock turbine...
Edited by z-monster
    • Agreed, I've never seen a 260RS specific manual. As GTSBoy said it will mostly be stagea other than the engine loom https://www.hgeconsulting.com.au/stageaservicemanual.pdf
    • You'lll likely have to make do with R33 GTR for engine/tranny stuff, and Stagea for the body. I don't know that there's even been an actual diagram seen in the wild.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
