  • 2 months later...
  • Replies 111
  • 1 month later...
Well looks like Paul and Adrian have upgraded long motors, Charlie is back for another round and some others getting into the drag racing action. Any chance of seeing a heads up Skyline shootout in the near future? Bring it on!
Might *finally* be ready soon too, hope I have gone far enough to have a chance.... at the top 7 at least :huh:
Thats a hot box you have there Chris
Crate of bagels?
Might *finally* be ready soon too, hope I have gone far enough to have a chance.... at the top 7 at least ;)
Big enough box to not be "half baked"
Box too big for RB
Lenco CS1 sold
Questions on the Pro Street Forum about 2 x 80mm vs. 1 x 101mm
Already owning 1 x 80mm
Car with massive wheel tubs
More likely to fit in here than here.
Adrian
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
