I had about a 50hp increase from just putting a RB25neo turbo and a fmic on my stock RB20..
For my RB25 i am getting a KKR480.. have a look here the KKR430 would work a treat on an RB20!
Edited by RB_turbo_bitch
https://www.sau.com.au/forums/topic/140367-turbo-for-rb20/#findComment-2616830
^^^1 bar will NOT get you there. nor will any other boost pressure. couple of mates have has this turbo on rb20s and the most either got was 205, other was 185. both after tuning. driven the one with 185, response is about the same as that of a turbo capable of 240rwkw... you'd think a 0.58 turbine A/R could achieve so much more...
orginal question:
ryan (1400R) is right, the td06-20g that he's selling (quite cheap too) will get you there. it also has the smallest exhaust housing and is quite a good match for the rb20.
another option is the gt2871r from garrett, but with the stock rb20/rb25 exhaust housing put on it so that it bolts up. horsepower in a box offers this.
these are the 2 options that i'm tossing up between (or was till i realised i dont have the money for support mods). both make similar power and similar response, with the garrett maybe a little bit better as its ballbearing
Edited by salad
https://www.sau.com.au/forums/topic/140367-turbo-for-rb20/#findComment-2618878
"or was till i realised i dont have the money for support mods"
what supporting mods you only need a fcd and a fuel pump
most should already have a larger fuel pump fitted so you only need a fcd $250 easy
remap it later when you've got some more cash together
https://www.sau.com.au/forums/topic/140367-turbo-for-rb20/#findComment-2620164
Maybe...but there are plenty of RB20s blowing up.
But the ones with SAFCs, FCDs and off the net re-maps seem to blow up mire only makign 180-200rwkws. There are a few RB20s with 2530s making 210-220rwkws with Pfc, there are some RB20s running bigger Garrets etc making over 230rwkws reliably with management. Its not a perfect rule but i think its more then just a coincidence?
Just my thoughts, but why spend the money on a new turbo if you can afford to get the ECU to run it. Its only goign to give asmall increase in performance and cost you more in the long run.
Im all for doign things on a budget, but tune maketh the car.
FCD, that doesnt even change the ignition or the fueling does it> Doesnt it just stop the std ECU doign the fuel cut dance when it senses too much airflow?
https://www.sau.com.au/forums/topic/140367-turbo-for-rb20/#findComment-2620583
yeah, i'd rather wait till i have all the money to do it properly, just in case.
want injectors, new pump (dunno if i want to trust a 16yr old gtr pump), and would want it tuned straight away
FCD as far as i know changes what the ecu 'sees', similar to SAFC
for rb20 may aswell just get the stock ecu remapped and tuned, does the job well
Edited by salad
https://www.sau.com.au/forums/topic/140367-turbo-for-rb20/#findComment-2620749
Remaps ftw... hehe
All i can say is less lag is important on a standard rb20! It won't run like an rb25 off-boost, or even an sr20 for that matter lol
14psi wont do much on an rb20 either, you really need 17++ psi plus alot of rpms to start to make any real decent power on MOST turbo's
The TD06 seems like a pretty good choice, i have the gcg hi-flow (from a r33 turbo) and its abit laggy really...
When it gets going its great like on the freeway etc, but waitin for it to spool up can be frustrating esp in low gears, 1st gear is nothing nothing then all hell breaks loose for half a second LOL
Edited by jazza08
https://www.sau.com.au/forums/topic/140367-turbo-for-rb20/#findComment-2621438
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
