what is holden on? aparently a new holden "hummer" at sydney auto show or something on news today
is it the same as a hummer h2, is it cheaper,what engine?
i spose holden need a new large 4wd
what do you guys reckon?
IMO cheap hummer rip off P.O.S, but then again how much is it worth and whats it packing
https://www.sau.com.au/forums/topic/140588-holden-hummer-wtf/
Theyre slightly smaller, weight wise than some of the big landy's and patrols with a GM Atlas truck motor in em. Basically the softy-poofta version of the military one, dunno if theyre any good as an off road vehicle I'd have too ask some of the 4wd nuts at work when they get back from their Tassie trip if they know what theyre like.
Cant see them landing them here for much less than 75-85k though and thats not exactly cheap and probably not that most owners would take them too play where rocks, sticks and mud could gunk em up.
The low down says GM Aust may be selling the H3 by mid to end next year. The H3 at the motor show is on the Holden stand to gauge public reaction and is a 3.7l 5-cyl petrol.
Very basic and SMALL in the driver/passenger compartment and ugly as a hatfull!
Holden is definately on something. Look at their recent decision making skills:
Should we import new Vauxhall VX220 Turbo as an HSV model? Nah, no one wants a 4cyl turbo HSV... So we won't import this Lotus-Elise-but-cheaper-and-turbo-charged at all. But wait! Should import the 4cyl turbo Astra VXR as an HSV? YES!!! Everyone wants a 4cyl turbo HSV!!! :D I'm confused...
Import the new Vauxhall Corsa (Barina)? No, we'll import the Daewoo Kalos instead! Import the next generation Vauxhall Vectra? No, we'll import the Daewoo Tosca instead. We've got all the 4wd hardware to make a quality 4x4 like the Ford Territry. Nah, can't be bothered, we'll import the Daewoo Captiva instead. Everyone hates the Daewoo Lacetti (Viva), right? Of course they do, so we'll import that too!
Great! We've got HEAPS of Daewoo's on sale now! We're sure to reach the top of the sales charts now that we've replaced our entire quality European line up with the same Korean line up that sent Daewoo bankrupt!
So now the entire Holden badge has been cheapened by inferior Korean product. Hmmm... The only thing we're missing is an American car... Cadillac CTS-V? Chevrolet Corvette Z06? Nah, in this time of environmental conciousness and high oil prices, what we need is the new HUMMER H3!!!
:) SEROIUSLY HOLDEN, WHAT THE HELL ARE YOU THINKING!?!?!?!
These decisions are even worse than Toyota's "let's sell the Avalon instead of the Chaser" decision...
P.S. Nice VL ctjet, I like it a lot! Pity about the rims, though...
Edited by Big Rizza
Ahahaha......classic but soo soo true
can't the government just flat out ban the f**king things? We don't need more stupid large cars on the road.
Whenever you are driving around and struggle to see around one to see what else is happening in front of you (basic hazard avoidance), or everybody time you see somebody struggling to get into a "regular" carpark or worst still take up two carparks in a crowded shopping centre you just think "you stupid f**king selfish c**t"
:( SEROIUSLY HOLDEN, WHAT THE HELL ARE YOU THINKING!?!?!?!
Thinking with their wallets - I bet they don't have a slump in sales due to these Daewoo brands and they also save heaps of money compared to bringing in Euro GM cars.
The Viva is selling only about 1/2 what Holden expected, but Barina is (unfortunately) still selling strongly. :( I was so hopeful after the Barina's breif sales slump after the press release concerning it's 2 star safety rating, but it seems to have sprung back to it's 1200 units per month sales norm...
Edited by Big Rizza
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
