I just got a phone call from my sister who lives at Mount Pleasant - she was on her way home this arvo and was first on scene to a bad Skyline accident. She couldn't even identify what model Skyline it was - it was smashed too badly (and then caught fire). The driver was apparently a 25y.o male from Birdwood and was killed on impact with a tree. His 2 brothers (Aaron and Matt) were in the car and injured but not life threatening. Apparently it looks like the car was going too fast for the corner and collected a tree at very high speed.
Please be careful guys - this could happen to any of us if we go hooning through the hills and don't drive to the conditions.
Just something to ponder ....
https://www.sau.com.au/forums/topic/140937-another-skyline-death/
yeah wow condolences to his loved ones
not to be rude but he hasnt got anything to be thankful for anymore
remeber ppls SPEED kills ... well its not the speed its the sudden stop when all goes wrong .. and how easily it can all go wrong
RIP and my heart goes out to the family. Just remember that with speed and power comes responsibility - such a fine line between being dangerous and having fun. I agree with the practice days out at Mallala being the place to be to open it up - too many other things can go wrong on the public roads (animals, people, other cars and trees)
Madaz speed does not kill, but iresponsible speed can kill.
yes thats why i changed it a little
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
