Hey all,
I purchased my first skyline about 2 months ago now (1995 R33 GTSt). Claiming that it has done only 60,000ks... im sure thats crap with how easy replacement clusters are to get, but the actual car is in very good condition.
Now i seem to get about 320km out of a full tank of PULP (V power) and i just think that i should be getting more than that considering i dont very regularly drive it hard.
The car is completely stock minus the factory air box being replaced with an Apexi power intake. But the effeciency was about the same when i did have the factory intake.
The engine seems to run very smoothly but can sometimes produce a very off smell that may last for 30 seconds and then all is fine again for the rest of a day of driving... (i thought the smell issue may have been a clutch issue at first as when i got the car it happened mainly when reversing... high slippage when parking, but now its just very random)
Any ideas or suggestions?
Cheers
Cam
https://www.sau.com.au/forums/topic/141124-r33-fuel-efficiency/
  • Replies 69
Posted Images
Lots of topics on this.. Do a search!!
320km on a stock 33 is really bad..
You might need to do a full service.. Maybe replace 02 sensor.
Car running rich but? Shouldnt be if its stock!! if it is might need a tune up..
Maybe also replace fuel filter and oil filter..
As for the other issue if its the clutch then you should know it immediately. Does the car tend to rev but not go anywhere??
Or the clutch only slips in reverse gear??
Probably worth gettin a new clutch then reconditioning it.
firstly, how many litres are you talking about as a full tank?
secondly, how 'spirited' is your driving?
thirdly is it city (where you may be sitting in traffic for a bit) or highway?
all of these (especially the first one) will determine whether your economy is good or not.
:yucky:
if you're talking 320kms on 45 litres, then that's 14L/100kms. that's not too bad in city driving, boosting occasionally. if you live out in the sticks, then alot of freeway should see that figure go up quite a bit, maybe 11L/100kms.
Lots of short drives also consumes more fuel as the car isnt up to optimum operating temps.
Also, driving style makes a big difference.
I wouldnt say this is terrible economy.
Im running stock boost, Blitz Pod and HKS Priest catback. I get about 320-400Km per say 55-60 Litres. That is with a bit of 'Spirited mountain driving' :yucky:
Id say I get between 12-17L/100KM depending how I drive. So it would theoretically be possible to get 500 Kays to a tank... If I put a phone book under the accellerator...
As i did say my driving is very casual 90% of the time so im not wasting juice on that. I'm filling up the tank till the pump wont gime any more :) and running down as low as the guage can basically go, but not enough to turn on the fuel light. I also dont appear to blowing and black smoke, very clean exhaust from what i can tell.
I am mostly doin city driving but i have a place down the mornington peninsular and when driving back and forth from there the effeciency really doesnt increase by much at all (maybe 360-370km). This really surprised me as my old car would give me 100ks more per tank when doin only 100km/ph driving)
As for the clutch issue, no the clutch takes up perfectly fine when driving, no unwanted slipping.. i was refering to like when i reverse park there is slippage caused by myself of cause and thats what first made me think it could be clutch coz thats when i first smelt it, but it doesnt seem to happen then anymore... just randomly during general driving, and i might drive the car for an hour or more after and it never returns.. strange..
i must have typed something wrong as i did do a search for "topics only" on fuel effeciency over the entire SAU forum and got nothing relevant. Most searches ive done using "entire post" has given me so many unrelated posts ive stopped using it..
But thank you all for your responses so far. It's gettin close to its first 5000km since ive owned it so i'll prolly get em to do a more thorough look over the vehicle.
Cheers
Cam
My bog standard R33 GTS-T gets almost 500km to a tank... less if I'm driving, but about that when my wife has it. - I forget what the fill volume is, but $60-$70 at $1.3L = ~45L
That's mainly city driving although it does get ~4 45 minute Hwy trips a week (out to the folks and back).
It's worse than my Lancer, but better than my Laser (although that may have been pissing fuel out of the pump so it doesn't really count).
I havent been able to source exactly where the smell was coming from but next time it happens i'll try and pin point it.
Is there some way i can find out if unburnt fuel is making it to the cat without pulling out that section of the exhaust?
Also what would cause this over injection of fuel? its the stock ECU as u've all prolly gathered so mixture cant be changed there, but would it be becuase say the air flow meter is reading higher readings than is actually making it into the manifold?
Thanks for ya help all
Cam
factory fuel tanks take 65liters of juice
Rather than just guessing what a tank of fuel is, calculate your consumption. When you fill the tank see how many litres it takes to fill it, note your kays & work it out. It does sound from what you've said though as far as the needle reading empty, that your consumption is poor.
If you don't think your O2 sensor has been changed DO IT! I personally left it longer than I should have (& I should know better), it was completely shot & I was getting about 15L/100km. Now I'm doing around 12L/100km give or take a bit. Most of my driving is is the city & I do give it a bootfull off the line quite regularly. Cruising on an interstater I'd see 10's easy, maybe less.
Most people don't realise how important an O2 sensor is to your economy but it's vital to getting good consumption. It should be changed once every 5 years & it's worth it. I'm now saving at least $10 a week or about $520 a year on petrol to what it would cost me if I hadn't changed the sensor.
NTK 1's retail for something like $130, you'll get your money back within 13 weeks if you go through a tank a week at the moment, or even more if you travel further.
Oh & you can probably smell fuel when the car is stationary wafting in though your window or vents, since it'll be running rich as. Look at your rear bar, if it's getting lots of black crap on it she's rich as buggery.
Edited by JazzaR33
So even if my 96 S2 has around 54,000 KMs on the odometer I should replace my O2 sensor?
Hmmm I might do that at the next service... dunno whether to get the EL falcon O2 sensor or buy a genuine R33... any advice?
sir d - NTK make a direct replacement for about 100$ odd dollars.
It's pretty much the same price as the el sensor, but has the correct plug.
I disagree with you guys. I have a consult screen, and I have have used the consult interface with my laptop to graph the o2 sensor output.
My fuel economy is shit - about 300ks to a tank. But the o2 sensor is fine.
Can I have the NTK contacts? A site perhaps?
Cheers.
I think you should follow what siddr20 has said :yes: the filters can make a huge difference.
How many litres are you using?
I do around 380KM to 45Litres (And the needle is pretty damn low!)
I've never wanted to go any further, as I never knew how much fuel and R33 held until just then.
But with my economy... I'm in the 11L/100km gallery.
Sir-d, Kudosmotorsport on here sells them..
http://www.skylinesaustralia.com/forums/in...howtopic=135194
Btw yes changing your fuel filter will help a lot..
But since my car has a few mods and runnin rich, a good tune will help me towards my fuel mileage..
Otherwise for a stock car, i reckon the fuel filter. BUt if people claim 02 sensor helps then worth a try!!
Thanks!
:ninja:
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
