Hey guys,
Got some spare parts of my 94 S1 R33 Gtst which have just come off the car! Live in Hobart, Tasmania!!!! so i can send them if buyer pays postage!
I have the following
1 x Stock R33 Turbo 65,000km minimal shaft movement $350ono..........SOLD
1 x Stock R33 Manifold, good condition $150ono
1 x Stock Set of R33 Camshafts, good condition $200ono
6 x Stock Injectors, unsure of condition (will ask mechanic) $150ono
1 x Stock AFM, unsure of condition but was working ok & pfc said it was fine $50 ..........SOLD
1 x Stock ECU $150ono
1 x Custom built Stainless steel Split Dump/Front pipe from Advan, very good condition $350..........SOLD
1 x Stock Cross over pipe with stock BOV, good condition $75ono
1 x All pipe work on the Turbo side to suit stock turbo, $125ono
1 x Stock Ex. Cam gear, good condition $25
1 x Stock Suspension with Lowered Springs, good condition worked fine $250ono
1 x Whiteline Adj Rear Upper Control Arm Kit (New) cost $300+ will sell for $225ono
2 x Federal Tyres 75% tred 18/235/40 $100
Probably have a couple more parts as well but I will have all these parts buy the end of the week! Buy the way I am negotiable on parts to an extent & would prefer to sell them locally or else the buyer will have to pay for freight!!
Might be able to put some pics up if I get time!
Pm me if interested
Cheers
Alan
Edited by al_r33
https://www.sau.com.au/forums/topic/141202-parts-for-sale/
Cheers Leigh,
tridentt150v,
The Dump pipe is the exact same as this one!
Musky,
I don’t have time to Organise freight! But if you can then I would be more than happy to drop them off!
Cheers
Alan
Edited by al_r33
https://www.sau.com.au/forums/topic/141202-parts-for-sale/#findComment-2630213
  • 4 years later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
