Hi all,
Well my Sard 800cc injectors arrived today (only took 4 days from greenline!) and i went to plug them into the std loom, but the plug on the loom has a different shape to that on the injector (loom is square, injector is round) also the plug that came with the injectors that replaces the std plug, seems to be upside down when 'clipped' onto the injector. Car is R32 Gtr.
Just want to know if i have received the wong injectors, or i've missed something.
cheers
Shane
https://www.sau.com.au/forums/topic/141283-sard-800cc-injectors/
yep same with our sards...side feed on rb25 had to rewire the plugs. Then the bottom of the silly plugs were fouling on the manifold and we had to shave the arse off abit so they would clip on properly. Note thats on a greddy manifold incase anyone else goes to put them on using the std fuel rail.
Shane you sure yours are 800cc, cause i check our sard boxes for the injectors we put into the 25/30 and it clearly states 850cc unless im blind or the boxes are wrong? Maybe top feed and side feed are different?
Edited by r33_racer
had the same problem with my 800's on my gtr... you hav to actually modify the injector slightly... get a stanley knife and trim of the two slot from either side of the injector where your plug slides down... you now can turn the plug around the right way...
The biggest direct exchange Sard injector is the 700cc item for the RB26, the 800cc items require the wiring of new plugs and also injector plug modifications, even with supplied plug.
Cheers lads. Pretty piss poor effort on Sard's behalf, they should fit straight in, and even the plug they supply isnt right!
Micheal, on the box it says 800. Heres a pic of the box and the injector & plug.
Also, does it matter which wire goes what side? (i havnt taken a look at the wires yet)
yes i had same problem wouldnt plug in properly had to shave as well that was on the standard fuel rail
didnt want to wait the few weeks from japan....Sards are normally always in the country a day away on overnight freight.
But anyother time would definetly go nismo items for thats true bolt on awesomeness.
Edited by r33_racer
maybe the $300 difference has something to do with it? :rofl:
I honestly bought these thinking they were a direct replacement, and that's how they are sold aswell. Spose its not too big of a deal, just a pain in the A.
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
