ok..
ive driven a few cars. with the 3 variants of tein comonly available.
superstreet. abit firmer then stock,good solid feel.(on a evo 9 its actually less bumpy than stock :))
flex.. quite firmer than stock. abit choppy
mono flex. about the same firmnes as flex but without the choppyness. very good feel.
to be honest i was very impressed with the mono-flex. id of thought they would be bouncy as. no bumping around at all. just good solid feeling suspension.
alot people dont like d2 hehe...
I've yet to see a problem (and i taken my car to 3+ drift praticse, 1x Mc Day, 2x Drag Days)
im not sure how many km i have done (most likly over 20,000km with them) but no problem.
Althou when i 1st bought them i had a knocking problem from the rear 2. i took them back and they got replaced under warranty asap! since then i havn't had a problem maybe there was a set of bad ones?
ISC, D2, G4, Racing Logic all look the same but are different colours. The cheap shock is masked by huge spring rates. Also have a look at www.isc-coilovers.com They claim to have lots of R&D and testing, but they came up with some pretty odd solutions for spring rates for skylines, namely the same for 32, 33, 34, 2wd and 4wd, despite the massive difference in handling characteristics and weight distribution.
They are also only bound adjustable and let you choose your own spring rates. I asked the guy a while ago if they revalved the shocks to suit the custom spring rate and they dont, so you will be lucky to get a shock that can control the spring properly.
Personally, I would stay away from all the cheapies.
Edited by salad
Apart from the fact that the bloody things fall apart (my rears have died twice in just over 12 months, I have seen customers with them where the shaft has bent over 45 degrees from street driving, etc) the lack of rebound adjustment is a bloody killer
I just dont understand how a shock is supposed to control a car with only bump adjustment? they dont work well at all, decent matched struts and springs are miles ahead of D2s
Michael, what sort of quality control allows NEW rear coilovers (both of them) to be sent out in a defective state? How happy would you be if your brake pads came out to you in a defective state? dodgey
There's more to brakes than you think mate, not something to skimp on in my opinion. Having said that, I haven't used them, and don't know anyone who has, so can't comment.
As for suspension, I use Tein Super Streets, and the car is 90% track use, and I'm very happy with them. Comfortable on the street, stiff enough for the track, a good compromise.
Agreed totally!!
I think the point of having just bound adjustment on the cheap coilovers is the wanky "I adjust it softer for daily driving and then make it full hard for the track to make it handle siiiiiiick"
Even if they did have rebound adjustment, there is no way that it could have a damping range large enough to cover all the spring rates they offer (2-22kg/mm). Shocks really do need to be valved to suit the spring. Damping adjustment should be to FINE tune your suspension.
I also noted that they are all base height adjustable and that they offer their coilovers for a MASSIVE range of cars. So I wouldn't be surprised if they swapped the bottom and the strut top and had it suit a different car. If this is the case, it means they have a handful of shocks and they all supposedly suit around 50 different cars...
Anyone else have any thoughts on this?
Edited by salad
Agreed again. The base adjustment is basically the easiest way to make the whole package "universal fitment". everything else maybe wrong for your car, or your application. Valving, Spring rates, even stroke lengths and shock body lengths could all be wrong.
I drove an A31 cefiro at work that had k style coil overs in it as well as 17's .
there is about a 15mm bump going into our workshop and my teeth nearly fell out when i hit it going very slowly it also bounced all over the road to the point of being dangerous. Why any one would chose to drive a car like that is a mystery to me.
GOOOOD, I'm glad someone has some common sense not to buy cheap crap....
YOU GET WHAT YOU PAY FOR
HA HA you have had this argument before huh? Learn to do what i do. When people tell you that you are wrong and know nothing and brands such as D2 are better, just say "ok" and move on. Eventually they will learn by their own bad mistake.
werd. :rofl: its funny you know. i learnt the hard way. i was pretty naieve the guys like the shock is made and designed in japan etc etc the spring/body is taiwan to make it afordable bla bla bla.
i mean they cant evan get th surface finnish corect on the damper shaft its self. i had 2 lots of rears go in 6 months. by the shaft being to grippy and pulling the seal thru the top of the damper pissing oil everywhere lol.
i pulled them out and put in some heaps old blistiens and havent looked back since. its no longer a pogo stick. despite having the SAME springrates.
recently as per my earlier post. the curent tein monoflex is really good. just such a good feel.
and for the record. a colegue of mine happerns to have a taiwan manufacturing magazine. and there all in it:
K-SPORT,D2,G4,ISC,HSD, AND THE LIST GOES ON some other brands too that alot of people think are made in japan i wont mension them but..its alll cominmg out of the same factory.all in a nice 10 page glossy advert. lol
so if one goes ahead and orders 'r32' specced g4 or HSD coils, are the shock valvings EXACTLY the same as if you were to order 's13' specific?
What if you specify your spring rates when ordering...? i assume the answer is NO, but do they use different shocks for your application?
i recall there was also some drama regarding issues with kei-office coils, does anyone know if this was due to cheap/incorrect shocks being supplied?
...and for the record. a colegue of mine happerns to have a taiwan manufacturing magazine. and there all in it:
K-SPORT,D2,G4,ISC,HSD, AND THE LIST GOES ON some other brands too that alot of people think are made in japan i wont mension them but...
Why not mention them?
At the end of the day, quality control, R&D, manufacturing standards and material specification is important - China and Taiwan CAN make quality, but it costs more. From what I understand, very few coilovers are manufactured in Japan any more - its interesting though that Bilstein have some products produced in japan - according to my sources.
And I am pretty sure HSD are manufactured in ROK, not Taiwan/China
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
