  • Replies 209
I have SR-071, came with the car and i was going to get rid of them till i found out what they meant (i thought it was someones birth year and initials) the sr71 is a reconnaissance plane that was retired in 1998 but still holds speed and altitude records to this day, it is also the only millitary plane that has never been shot down due to the fact that it could out run missiles, here is a wiki link and pic below http://en.wikipedia.org/wiki/SR-71_Blackbird
It is also nick named the blackbird which fits well since my car is black.
Edited by W0rp3D
  • 3 months later...
oh i saw the best number plate today in syd.. walking down my street and i see a s15 with the BOV hissing
with numberplates 'V8KILA"
how sweet is that :blink: LOL
Yeah, that thing is pretty quick too :D
I got 4RANSM..explains everything :-)
Was that on a 350z before?
I have YF.34.RR on my R34 :D
Currently on ebay:
TWNCAM - vic
YUMMMY - nsw
WSSSup - vic
NO1MAN - vic
HUSTLE - wa
DAGAME - nsw
SKYGRL - vic
H8RICE - vic
BOOKIE - nsw
OVRSZE - vic
HIBABY - nsw
NOREGO - vic
JAPJET - on a pulsar
ORGSMK - on an RX3
CVIEW2 - vic
BMY80Y - nsw
ISTRBO - vic
BABE1 - wa
HOT AZ - nsw
PAR1S2 -vic
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
